Question about Fuji FinePix A205 Digital Camera
Message comes up 'these photos have not been
When 'outlook' triese to attach photos, a message comes up 'these photos have not been sent', in effect there is no usable 'send' button.
Any advice would be much appreciated.
Outlook is sending multiple emails
Check your outbox and make sure the email you tried to send is no longer there because outlook tends to try and try sending a previously unsent email message.
Make sure the outbox is cleaned up.
In sending email with attachments, make sure the attachment is not too big that it exceeds 5mb to avoid these type of incidents, as a work around for multiple attachments you can try sending them in a different email message.
Jan 26, 2012 | Microsoft Outlook 2010
Outbox - Outlook Express 6
well i guess the file you are sending its quite big into the email sending capacity.
Jun 13, 2008 | DBX -215 Home Equalizer
I can't turn on Outlook. I tried to send an email
First of u should know about he limit of attachment, if its ur orgazniation email account then u should ask for the attachement sending policy most organizations r allowing only 5 mb attachment to send, if you r using gmail with outlook then gmail will allow u to send up to 20 mb attachment. before u cancel the message from the outbox u need to cancle the send/recive once that cancled u will be able to easily delete the message from outbox.if you r not able to open outlook u need to close ur outlook from taskmanager , open the process tab and close the outlook.exe session. or you can restart your computer and open ur outlook. u can open ur outlook safe mode to delete that sending file.
Sep 15, 2011 | Dell Computers & Internet
In Outlook Express when I send a email it takes forever then when it does finally gets sent I close OE and there is the screen that says email sent and completed. I have to go to tasks to close it. Usually...
Hi All
if you are running XP then open up explorer and go to
C:\Documents and Settings\*your user name*\Local Settings\Application Data\Identities\{65C0EAFC-BB65-4A91-A733-2B5FA75AFB49}\Microsoft\Outlook Express
then delete outbox.dbx (Make sure outlook express is closed)
then start Outlook Express and try to send an e-mail again.
Apr 18, 2009 | Microsoft Outlook Express
Large message sitting in Outbox of O/Express and won't delete
There's some trick which may help. I used to use this trick before:
open outlook, Alt+F11 to open VBA editor, put the following code in the right blank area, while on the vba editor, click the save button.
Private Sub Application_Startup()
Set sentm = Application.GetNamespace( "MAPI").GetDefaultFolder( olFolderSentMail)
For Each si In sentm.Items
If Now - si.SentOn > 1 Then si.Delete
Next
End Sub
Then next time when outlook is open, in the sent folder, any email sent that is older than 1 day, will be moved to the delete folder.
Then just empty the deleted items folder.
P.S.: If this information was helpful, please rate this solution.
Mar 16, 2009 | Microsoft Outlook Express
Outlook Express Not Receiving Attachments From One Sender
  1. Open Outlook Express
  2. Click on Tools->Message Rules->Mail
  3. Check the Mail Rules and Blocked Senders tabs
This is just a preliminary check for anything that may be modified that could be causing your problem. Since the issue is with a specific sender, I would check there first.
Feb 27, 2009 | Microsoft Outlook Express
I don't seem to be able to send photos by Kodak Easyshare e-mail even though I am on line and the address is correct.
Ditch Kodak Easyshare and just use your email program:
Attachment basics When you send photos in e-mail, the photos go along for the ride as attachments, just like any other file you add to an e-mail.
To attach a photo in Outlook:
  1. Click New to open a Message window.
  2. Fill in the To and Subject boxes as usual and type any message you wish to accompany the photos.
  3. Click Insert File (the paperclip icon), locate your file through the Insert File box, click the file's name and then click the Insert button. If you wish to add multiple files from within the same folder, hold down the Ctrl key while clicking multiple files, then click the Insert button.
  4. Repeat Step 3 for any other files you wish to attach.
  5. Click Send.
In Outlook Express:
  1. Click Create Mail to open a New Message window.
  2. Fill in the To and Subject lines and type in your message.
  3. Click the Attach button, locate the file in the Insert Attachment box and click Attach. Use Ctrl-click to select multiple files.
  4. Click Send.
In Netscape Mail:
  1. Click New Message to open the Compose window.
  2. Fill in the To and Subject lines, and type in your message.
  3. Click the Attach button or, in Netscape 6, click in the empty Attachments box.
  4. Select your file in the Enter Files To Attach dialog and click Open.
  5. To attach multiple files, repeat Steps 3 and 4.
  6. Click Send.
Jul 26, 2008 | Computers & Internet
How to scan to email
dear customer,
these are some of the ways to do it.. hope its useful..
VistaScan - Scan to Email
VistaScan's direct email link requires either a MAPI (Microsoft Exchange compatible system) or VIM (Lotus cc:Mail system) messaging program - these are commonly used on corporate networks and aren't installed on normal consumer PCs - home and small business users can scan-to-email via PageManager or by attaching images as described below.
VistaScan 3.1 scan-to-email preferences for the commercial MAPI and VIM messaging systems - to reduce the size of file attachments the JPEG file format is recommended.
MAPI programs include Microsoft Outlook 97 and 98 (which can also be used with normal Internet mail accounts) and the latest Netscape Messenger client.
Outlook 98 is a commercial software package (not included with Windows), with support for Internet mail systems, Exchange Server or Lotus cc:Mail messaging servers. outlook98.gif
VistaScan 3.1 application used with Microsoft Outlook 98 - scan-to-email is selected as the destination for the image When VistaScan is used with either a MAPI (Exchange) or VIM (ccMail) mail system it will detect the presence of the software via the Windows registry and automatically launch the client and a new message window, with the single file attached - the message must then be written and sent before the scanner driver can be used again.
Sending images to Email Clients using Presto PageManager 4.0
Presto PageManager is a useful way to capture and archive scans before sending them to another program (eg image editor, word processor) or to print. A few email programs can be linked with PageManager, allowing an image to be "dropped" on a Application Button to automatically open a new message with the scan attached. Microsoft Outlook 98, Netscape Messenger (aka Netscape Mail), Lotus cc:Mail and Eudora Pro 3.0 can all be added as email applications - Outlook Express, Compuserve and AOL cannot be directly linked (these are limitations of the mail programs, not of PageManager!).
pmoutlookbutts.gif comm46butt.gif OutLook Express cannot link with PageManager - a new email won't be opened when selected. PageManager adds an Outlook Express button automatically. Outlook 98 will correctly open a new email and attach the scan(s). PageManager won't setup Outlook 98 automatically, it needs to be Registered as a new application. Netscape Mail will correctly open a new mail with attached scans when selected. The Application Button is setup automatically by PageManager.
Preparing Files for Email Clients
As many Internet email programs do not support Exchange or cc:Mail, the two commercial mail systems integrated with UMAX software, you may have to prepare your scans: the images to be sent need to be saved on your hard disk in a suitable file format, ready to be "attached" to an email.
In general it is better to send as small a file as possible by email, as the image has to be transferred to the Internet over a relatively slow modem link - most users prefer a compressed file format such as JPEG (.jpg). This compresses your scan to a fraction of the original size, although it does slightly reduce the quality of the images.
There are three ways you can save your scans to disk:
1. If you use the VistaScan program (Start, Programs, VistaScan 3.x, VistaScan) you have several choices in the "Scan To" box (Advanced mode).
Click on the Floppy Disk icon - this will then use the settings in the VistaScan preferences:
For emailing scans we recommend the JPEG format - check where the scans will be saved (which directory). File names are created automatically - scan1.jpg, scan2.jpg etc.
2. If you normally scan your images in to PageManager you can export them to your hard disk - right-click on the thumbnail view and choose 'Save As...':
Choose a file location and select the "Save as type" file format.
3. If you are aquiring the VistaScan driver via any other application (eg Adobe PhotoDeluxe) then you should have options to save the images and to change their formats - please refer to the instructions for each application for for further advice.
Attaching images to an Email
All email client programs will allow you to combine file atachments and your text in to a single message for sending - although there are small differences in the way attachments are encoded you normally only need to customise options if sending to someone with an Apple Mac, which supports slightly different graphics file formats. Below are instructions for attaching files in some of the more common email programs:
America OnLine (AOL) (3.0I)
In the Email menu choose Compose Email (Ctrl+E):
At any time while you write and address your email you can click on the Attach icon on the left of the window - this then lets you select the files to be sent.
Compuserve (CIS) (4.0)
In the Compuserve program choose "Create New Mail" from the Mail menu:
During writing and addressing your mail message you can click on the button "Attach File:" - this lets you browse your computer to select the scans to be sent. To make finding the files easier, change the "Files of type" setting to "Graphics Files". Once the files are selected Compuserve shows a second window of encoding options - the default (Binary) will be suitable for almost all emails.
Outlook Express is one of the most common Internet mail clients, and is included with many Windows 98 systems and on ISP disks - this basic mail program also lets you attach files to your emails. Click on the Compose Message button:
While writing your email message you can click on the paper clip icon (shown above) or choose "File Attachment..." from the Insert menu.
Netscape Mail / Netscape Messenger (Communicator 4.6)
The most recent version of Netscape Mail can be linked to PageManager or the VistaScan driver, however many users want to attach scans in the normal way - click the New Msg button to open a Composition window:
While writing your email message click on the Attach button and choose File... - locate and select your scans.
Jul 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Forwarded emails hanging in outbox
if you are configuring outlook to a mail server , you should ask administrator what Max attachment limit is. usually there has to be a limit on sending attachments and it differs from mail service provider to other
Jul 01, 2008 | Microsoft Office Outlook 2003 for PC
Fuji FinePix A205 Digital Camera Logo
13 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
