Back to:
Tags:
Jl Audio 12W3 Car Subwoofer
12w3v2 Started making distorted bass noise at low...
posted by hidalgo1301 on Jan 04, 2008
I recently installed a single 12" JL 12w3v2 in my vehicle. It is powered by an Alpine MRP-M450 amp wired to run @ 4 ohms with a rated 220w single channel. I have been running the sub hard, but not to the point of distortion. This afternoon I noticed that the sub was making some odd almost distorted noise at low volume. When I turn it up, the sub puts out good bass. I am worried that I may have blown one of the coils. How do I check to see if I in fact damaged the speaker, and if so, what could have caused this. Thanks for any information. Michael
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2008
Helpful (85)
sir fixalot
Rank:Guru Guru
Rating: 91%, 123 votes
Connect each speaker coil one at a time to a square 9 volt battery and watch for the cone to move.
Also try hooking another speaker to your amp just to make sure the noise isn't in the amp.
You can use a 9 volt battery to test wire polarity also. Hook up the + wire of the speaker to the + terminal of the battery and the - speaker to the - battery terminal. If the speaker moved UP or OUT then the wiring is correct. If it moved IN or DOWN then the + and - wires are backwards on the speaker.
Also if you have two or more speakers hooked together test all the same way while they are hooked to each other. ALL of the speakers need to move in the same direction at the same time.
Clipping causes more speaker damage than anything. "Dirty Power" can happen in good quality amps too. The gain control is to match the voltage between the headunit and the amp. It is NOT a volume or boost knob. If you overdrive the first stage of the amp and then clip it damage will occur to the amp and speakers at some point.
Hope this helps.
Rating Locked! (?) hidalgo1301 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 12w3v2 Started making distorted bass noise at low volume:
I don't want to Accept this solution
Can you Help with these Car Speakers and Subwoofers problems?
i locked my kenwood kdc mp338 when i unhooked my battery...
i have 2 12"jl w3-d6 & 2 mtx 250 4 ohms each so...
hey i have two pionears in the back of my car and two...
Stopped using my 12" W6 when I noticed a portion of...
hey i recently switched my system from my old car to my...
Loading problems.
Repair Service
Find Car Speaker and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
