Question about HP (F1470A) Internal LS-120 (SuperDisk) Drive
Hp f1470a ls-120 module
My Omnibook has final given up however, I need and have a use for the LS 120 as I have backed up material on ls120 diskettes.
Can I remove the drive from the carrier (plug & play craddle) and is there a usb device/craddle I can install it in. (concern re connectors here? )
The next part of the question:- do I need any drivers specifically for the LS 120 or will all MS operating systems reconize it.... If I need drivers where can I get them from and what are the details.
    Brigadier General:
  • 10,406 Answers
IMATION made SuperDisk drives with different interfaces: IDE (same as a hard-drive), parallel-port (like an old printer), and USB.
So, if the SuperDisk is "inside" your laptop, it probably has the IDE interface. It also may have another interface, to adapt from the IDE interface to the ribbon-cable interface often used inside laptops; just unscrew/remove/disconnect that "extra" interface.
What's left is an IDE interface (just like your hard-drive and CD-ROM) and a 4-pin power-connector (just like a standard floppy-drive) and a "master/slave" jumper (just like your hard-drive).
So, I would temporarily connect the SuperDisk to an IDE ribbon-cable inside your desktop, setting the master/slave jumper appropriately, and connecting the 4-pin power-connector.
Then, start Windows 2000/XP/Vista/7 and it will automatically recognize the drive, without needing any drivers.
Copy each of your diskettes onto your hard-drive, and burn CD/DVDs, and/or copy the files onto a USB memory-stick.
Shutdown, and undo the "temporary" connection.
Posted on Apr 23, 2009
Does not have fuel pump driver module , has rear electronic module ! The difference is it does more then just fuel pump control . I would google it to see what it looks like , then look in the trunk ,under back seat , Have seen them behind back quarter trim panels .
Feb 23, 2017 | 2002 Lincoln LS
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
2000 lincoln ls ac blowing hot air I've replaced the heater control valve
You need a scanner to diagnose,not a code reader.
The DATC Module ( Dual Automatic Temperature Control Module) is a possible
May 21, 2010 | 2004 Lincoln LS
(11762) LS-120 (SuperDisk) Storage Media: I have an older USB LS120 Drive and need the drive...
Download the software for drivers at
Use the following activation code :
Run a scan with the software and install all the drivers you need.
May 18, 2010 | Imation (11762) LS-120 (SuperDisk) Storage...
Apparntly I have DRLS120 SUPER DISK DRIVERS ON MY COMPUTER AND I CAN'T VIEW MY 2HD 1.44 MB FLOPPYS USING MY 31/2" FLOPPY DRIVE. How do I remove these drivers so that I can use my floppy drive?
If functioning correctly, the hardware of the Imation LS-120 devices can read/write 1.44MB diskettes, using "magnetic" hardware, and can use the built-in laser to read/write the proprietary 120MB "SuperDisk" diskettes.
What problem do you have?
How about taking the diskettes to a friend's computer, along with a USB memory-stick, and copying files from the diskettes to the memory-stick?
Oct 31, 2009 | Computers & Internet
How do I change the bios battery. I have Hp omnibook 6100. I have looked the manual, but I could nod solve the problem. Thank you
You have to open the back cover..there u can find a CMOS battery on the motherboard(Round shaped battery).
Mar 04, 2009 | HP OmniBook 6100 Notebook
Imation LS120
My computer has such a drive (120 Mbytes/disk).
As a "random act of kindness", I will read them, and burn the files onto a CD-R. Reply to this message, if you wish to proceed.
Oct 17, 2007 | Imation (11762) LS-120 (SuperDisk) Storage...
HP (F1470A) Internal LS-120 (SuperDisk) Drive Logo
131 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
