Home | GE | Profile Spectra JGBP90 Gas Kitchen Range | Oven will not heat up
GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
By sostabarak on Nov 03, 2009
When starting the oven it will not heat up at all, no flame, nothing.
Best Solution
posted on Nov 03, 2009
Very Helpful)
localwonder
Rank: Guru  GE Ovens & Ranges  Expert
Rating: 92%, 2783 votes
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat(located inside the top area of the units body structure)
-- defective selector switch(located on the control panel, or part of the integrated control board key pad.)
-- defective gas safety valve(located on the gas valve assembly)
-- defective gas valve coils(located on the gas valve assembly)
-- defective flame sensor(located on the gas valve assembly)
NOTE(If everything checks out ok with the ignitior, and burner/valve assembly, this will lead to a failing control board)
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Offered very detailed insight into what the problem could be. " - sostabarak
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
I have a code of f7 coming out when tring to use oven waht does this mean
Answer
i have a gas ge spectra xl44. the stove top works. the broiler works. the oven does not. what could... (More)
Answer
I need instructions on how to light the pilot light on a GE XL44 Stove. Model#JGBS15PEA2AD
Answer
how do you take the warming drawer out to get at the wires of the bottom igniter?
Answer
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile Spectra JGBP90 Gas...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
