Question about Panasonic PT-43LC14 43" Rear Projection HDTV
TV Powers off
I recently replaced my TY-LA1000 bulb in my TV.It Worked fine for a few days.Now as soon as you replace the lamp cover The TV powers off and will not come back on until you take the lamp cover off after you unplug it and power it back on.The power lamp blinks yellow twice every 5 seconds.It work fine until you put the lamp cover back on.Could it be overheating or should I start looking for a new TV?
  • klpnut Jan 04, 2008
    Could you give me a Panasonic part number for the switch and a new lamp cover?
  • 579 Answers
I think the lamp cover switch is acting backwards. Should quit when the door is off, and only work when the door is on. Look closely at the cover switch and see if it is messed up somehow.
Posted on Jan 04, 2008
TY-LA 1000 loose wire
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 21, 2014 | Panasonic TY-LA1000 Projector Lamp for...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
WERE exactly is the Lamp in my T.V ?
You must remove the plastic cover from the front and just left of center there is a panel covering the lamp with a single screw. Under that the lamp is also held in with a single screw. Pull on the handle firmly to remove lamp. Replace with TY-LA1000 bulb.
Jul 05, 2010 | Panasonic PT-50LC13 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
I need to replace the lamp...how do i get it out?
Hi, well your TV uses the lamp enclosure TY-LA1000, here is a link where you can find the manual of how to get to the enclosure http://www.fixyourdlp.com/blog/2007/09/17/panasonic-ty-la1000-enclosure-replacement-instructions-guide/ and here is another one to replace the lamp on the enclosure http://guides.fixyourdlp.com/panasonic/TY-LA1000.php
Jun 27, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
145 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
