Question about SanDisk Sansa e260 MP3 Player
The device does not start - SanDisk Sansa e260 MP3 Player
  • 758 Answers
Try to reset the device by holding the power button for about 15-20 seconds...that should power the device..if that doesnt do it i would recommend that you connect the device to the computer and leave it for a couple hours...then try to do a firmware upgrade on the device...and let me know whats the outcome,....
Posted on Jan 04, 2008
How do I fix this problem
Try changing out the start device for the compressor. I don't know which model refrigerator you have, but Whirlpool has a decent start device kit that has most of the common start devices in it:
Whirlpool 8201786 Compressor Starting Device Kit AppliancePartsPros com
Oct 16, 2014 | Refrigerators
Tip
How to pin Device Manager to the Start menu
Device Manager is a handy Windows tool for managing and troubleshooting components and peripherals. There are several different ways to access the device manager, however each of them requires a few steps. For easier access, why not pin the Device Manager to your Start menu?
Pinning a program to your Start menu is a simple procedure -- just right click on the file name or icon and select "Pin to Start menu." However, the Device Manager is typically accessed from inside another window (usually either the System Properties screen or the Computer Management console), and you can't pin it to the Start menu from there.
In Windows Vista, you can hunt down the Device Manager using the Search bar (just type "device" or "device manager" into the Search bar) and right click it from there to pin it. In Windows XP, the process is a little more involved -- you can follow the same steps as for Vista, but XP's search feature takes much longer to find files than Vista's does, so you'll be waiting at least a minute or two. By the time the system finds the Device Manager, you could have already been done with the whole thing.
To find the Device Manager file in Windows XP, open up Windows Explorer (Start > All Programs > Accessories > Windows Explorer). Click the plus sign (+) next to My Computer, then navigate to C:, then Windows, then System32. In the System32 folder, find a file called "devmgmt.msc" -- this is the Device Manager. Right click on it and then select "Pin to Start menu."
on Jul 02, 2010 | Computers & Internet
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
Device cannot start code 10
Device cannot start code 10 means that you are using the wrong drivers for the device or the device has a problem try using system information for windows to find out what drivers it needs if that is the problem but if not the device might need replacing
Aug 03, 2013 | ASUS Computers & Internet
How to install webcam in laptop
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver
W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Jul 08, 2012 | Intel Computers & Internet
How do i get my webcan working
W7
hope this helps
Jun 28, 2012 | Dell Computers & Internet
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
Mar 15, 2011 | Computers & Internet
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Oct 09, 2009 | Tomtom ONE 130 GPS Receiver
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Computers & Internet
Cd rom wont start (code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Jun 21, 2008 | E-Machines Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
