The problem is with your RAM sir , if you know to remove the side cover of the machine remove it by un screwing the screws at the back side of the tower(machine), after that you can see a green color chip vertically fixed with motherboard, thats RAM it is locked with the to white color notches at the two ends of the RAM, hence you have to remove the RAM separately and have to erase the goled color contacts of the RAM using an normal eraser,
after that fix the RAM as it is by carefully watching the small cut in the RAM , the RAM should be locked inside by preessing it hardly to move inside the slot. the picture of RAM is this only , Thank you dont forget to vote.
