Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Component video issue
Help:
My SD-582HD5 has a component video problem.
when I place a component video on input 1 the picture looks awesome.
But when I place the same component video signal on input 2 the picture looks very red.
thank you,
ra
  • Pioneer Master
  • 8,617 Answers
You have a component not up to specs in your input 2 circuitry possibly a capacior. You would need a service manual to locate which item that isnt up to its rating. you can purchase the service manual for your set for 12.99 at the following link. They will emal it if you send them an email requesting it.
http://servicemanuals.vstore.ca/
Posted on Jan 21, 2008
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Tv wrks for 20 minutes, the the picture and sound shuts down
try cooling down tv with a fan to see if it stays on longer. if so, it's overheating. then to next step. feel for excess heat and look for dark areas on components inside. it may be obvious. if not, you may need to call a pro or replace the set. best buy use to do basic diagnostics for $25, but that was about 7 years ago
Nov 25, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Feb 18, 2009 | Pioneer SD-582HD5 58" Rear Projection...
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sd-582hd5 picture goes black
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
15 pin RGB Input
You are wasting your time if the component you're hooking it up to is not High Definition... Tv can't produce any better quality from connector to connector you have to up the type of signal being input.
Bill
Mar 09, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Vertical problem
should have taken it back day 1
Dec 12, 2007 | Pioneer SD-582HD5 58" Rear Projection...
HV adjust
DANGER do not adjust anything but screen voltage to each gun do this is the only adjustment you need to make
Nov 09, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
