FixYa.com
Tags:
RCA VR349 VHS VCR
Tapes won't play and won't retract when ejecting
posted by resres on Jan 04, 2008
Tape loads, then stops and ejects, but the tape doesn't retract into the cartridge. The loose loop of tape then gets hung up on the mechanism, making tape removal difficult.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 06, 2008
Helpful (85)
sedonix
Rank:Guru Guru
Rating: 86%, 436 votes
This is the most common VCR problem of all time. The piece call the idler tire is worn down and needs replacing. This is the little wheel in the mechanism between the 2 reels that flips back and forth depending on which direction you've told it to go. It has a rubber tire around it to allow some slippage so that the take up reel can go whatever speed it needs to as it accumulates more and more tape on it as it goes through your movie. Sometimes this tire is very difficult to get at so it isn't something you should try to do yourself unless very mechanicly inclined. Replace the rest of the rubber belts while you're at it.
Hope Ya Fix it!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these VCRs problems?
VCRs
hook up,s
I have a DirectTV reciever,... Answer This...
VCRs
orion vcr model vr0210
do not have manual. can put in... Answer This...
VCRs
VCR eating tapes when...
Everything works fine on my... Answer This...
VCRs
setting date on my JVC HR 636U...
I cannot change the DAY on my... Answer This...
RCA VR349 VHS VCR
vcr won't play
power is reaching the unit,... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
