Question about Hotpoint RGB745 Gas Kitchen Range
Oven Pilot How can I replace the oven pilot in a GAS Stove?
    Master:
  • 619 Answers
Open at the back cover , unscrew bulb /bring sample to appliance center , screw the bulb ,test oven then ok.
Posted on Jan 05, 2008
I have an old gas stove. No igniter.Lights with pilot light only. Stove top burners work fine.Oven does not ignite. The pilot lite is on.I smell no gas when I turn it on.
Pilot flame has to hit the thermocouple. If pilot is dory flame.will be weak and not reaching the thermocouple that tells the oven there is a flame and opens the burner. If the pilot is strong and no gas to burner than that thermocouple. ( 100% safely valve is worn out) replace that and you are good
Dec 30, 2017 | Kitchen Ranges
I have Magic Chef gas oven. Model CPR1100ADW. The pilot light don't light up nor does it come on. I don't smell gas coming from it. I can't figure what it is. Can you help me.
The oven probably has an igniter to light the pilot, and when not in use, shuts the gas off. Unplug the stove to replace the igniter. Enter your stove info and "how to replace oven igniter" on you tube for videos and detailed instructions.
Dec 14, 2017 | Magic Chef Kitchen Ranges
Oven not receiving any gas but pilot is working
Sounds like you have a weak ignitor (pilot lite) . The ignitor has to turn white hot , not red , orange , but white , to open the gas valve . Replace the electronic ignitor and that should get the oven working .
Aug 16, 2009 | Danby D9604 Refrigerator With Ice Box
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Hotpoint RGB745 Gas Kitchen Range Logo
64 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
