Question about Samsung DLP HL-P5663W 56" TV
Samsung HLN567W DLP whining problem
After 4+ years my Samsung HLN567W started whining in the bottom front. I've read about color wheel and fan noise. Is there any way to tell the difference?
  • 579 Answers
If it is the bottom front, it is the color wheel. To tell for sure, take the back off (fake out the cover switch) and listen to the fans.
Posted on Jan 04, 2008
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Dec 06, 2013 | Televison & Video
I have a Samsung DLPTV, picture is fine. There is a "whining" noise associated with the TV the whole time its on. Stops as TV shuts down, It's about 4 years old and have not replaced lamp. Could this be...
Google your model number; I suspect it is a bad color wheel--lots of these sets have a fan like noise or even a grinding sound sometimes called a high pitched whine.
The part can be customer replaceable and YOUTube has actual video instructions for its replacement.
Let me know if you have questions as I am here to help.
SD TECH---Steve
Jun 08, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP is making a loud humming noise
Most likely if you are hearing a fan like noise from this DLP it is not the fan.
These sets use a replaceable color wheel that before it fails makes either a high pitched whine or a fan like sound.
Part is usually customer replaceable and there are free written instructions and video instructions on YouTube for most models.
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
THE FAN STARTED WHINING AND NOW THE LAMP WARNING LIGHT IS ON AND IT WONT TURN ON. IS THE FAN A PART I CAN REPLACE MYSELF?
It's not likely the fan - it is more likely the color wheel making that noise and causing your set to shut down. See link for more info
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W makes a whining sound and then goes off
The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
Dec 11, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Jan 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
318 people viewed this question
Jerry Greenberg
Jerry Greenberg
