This is an indication of a protective shutdown. During the startup process, a problem was detected and the unit shutdown to prevent further damage. There's not a lot to go one here. Some measurements need to be taken in side the unit to be sure. A common failure is the capacitors on the power supply board. Any local service shop should be able to get you a reasonably detailed repair estimate. Post the diagnosis here and we should be able to walk you through the actual repair.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thank you sooooo much!
" - brandy5151
Popular Solutions for Polaroid FLM-3201 Television
I somehow managed to block four channels. I get all other channels. (Those channels I don't receive...
(More)
I somehow managed to block four channels. I get all other channels. (Those channels I don't receive (cable connection without a cable box) show a fuzzy black and white screen which suggests the tv is receiving all necessary signals.) The four I can't get now have a black screen. I do get the small info box at the top of the picture. I've tried seemly every menu option and combination. Is there a way to re-set the tv or remote?
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the...
(More)
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the codes listed in Direct tv's set-up. Any ideas or suggestions?
when I plug it in it causes buzzing/humming sound and flips the breaker. Already tried using a...
(More)
when I plug it in it causes buzzing/humming sound and flips the breaker. Already tried using a different power cord (from t.v to outlet) and plugging it into different outlets w/same result.
was turning off tv, it shocked me now i can turn it on but it goes to channel 4 no volume control...
(More)
was turning off tv, it shocked me now i can turn it on but it goes to channel 4 no volume control and no use of controls other than power button
