Question about Samsung BP59-00016A Remote Control
Samsung convergence adjustments
A technician showed me once hopw to do the Fine tuning grid on my Samsung HDTV with my remote.(BP59-00048)
I do not remember how to get back to that point so I can adjust it.
Can anyone tell me how to get to that point again?
  • 372 Answers
Hi.
Try pressing MUTE Then 1 Then 8 Then 3 using remote contrl.
If this is incorrect let me know but im pretty certain this is correct.
http://dysonmanuals.llc.nu/
Chris,,
Posted on Jan 05, 2008
    Genius:
  • 1,601 Answers
Please give TV model number
  • 1 more comment
  • Thomas Christopher
    Thomas Christopher Jan 05, 2008
    This is for the HL-P6163W, Please let me know your model number.
    To adjust manual convergence on your projection TV, follow theses steps:
    1. Turn your TV on.
    2. Let it warm up for 30 minutes.
    3. Press the Menu button on your remote. The Main menu appears.
    4. Use your remote to select Function, and then press the joystick.
    5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
    6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
    7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have.
      Note: You must do the outside crosshairs first.
    1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair.
      Note: Make the single horizontal line as white as possible.
    1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair.
      Note: Make the single vertical line as white as possible.
    1. Repeat for all outside crosshairs, and then for the inside crosshair.
    2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
    3. Repeat Steps 7 through 10 for Blue.
    4. Press the Menu button on your remote to exit.
    Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
    If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
    Thomas Christopher Jan 14, 2008
    Did these work for you ?
    If so please rerate as FIXYA.
    Thanks
    Did any of these work for you?
    Please let us know.
Red picture tube out of alingment how do you make major adjustment
Its done with the original remote--convergence in the customer menu should be looked at first---call up the crosses or the grid of lines, it has one or the other.
You first want to look to see if red out and then if it will move both up/down and left right where off.
If it will not move in some direction anywhere on the screen the convergence output chips the set uses are bad.
The set will or should have two hidden menus, one will bring up the advanced grid for convergence---input for that with the remote is Mute, 181 or 183----if you call up the wrong one shut set off and try the other number.
It is possible to converge the whole screen there, if memory serves me 7,8,9 change the color being adjusted DO NOT ADJUST GREEN FOR ANY REASON.
two buttons (different on different remotes will move the cursor around the grid (and the remote must have a button somewhere on it with "data" to save the adjustments.
Check in customer menu the convergence first---got movement?
Dec 08, 2012 | Samsung HLP5685W 56" Rear Projection...
How do i start auto convergence
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Convergence problem, how to fix with my remote?
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Jan 19, 2009 | Sony KP-53HS30 53" Rear Projection...
Samsung HCL4715W
IF THE CONVERGENCE IS NOT ADJUSTING COMPLETELY THEN IT PROBABLY NEEDS NEW CONVERGENCE IC's . ALSO CHECK OUT THE SHARPNESS OF EACH PICTURE TUB (CRT) THESE SET ARE NOTORIOUS FOR HAVING BAD CRT''s (WHICH ARE NO LONGER AVAILABLE).
DON.
Nov 06, 2008 | Samsung HCL4715W 47" Rear Projection...
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Mar 31, 2008 | Televison & Video
Adjusting convergence grid
i correct grid will look all white. all colors aligned up.
you should be able to move the lines with the remote. and you cant burn anything out by doing convergence.
Jan 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Can't adjust blue lines on grid for convergance
I would take a look at the entire circuit board the STK chips are sitting on... I have the same problem with a sony KP-57wv700 and it turned out to be the high voltage controller for the crts got fried... part # BA9759F and it can not be replaced as the entire circuitry around it got toasted also... I just ordered entire circuit board. mine was the D board in this case...
BTW, did you check or replace the pico fuses? 3 orange ones on each STK circuitry. Check their resistance with an ohm gage should show continuity. My case they were 3.15 A each...
Jan 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
  1. Turn your TV on.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung BP59-00016A Remote Control Logo
189 people viewed this question
Jerry Greenberg
Jerry Greenberg
