Question about Akai LCT3285TA 32 in. LCD Television
Akai TV Stuck in Video Menu Page
My TV is stuck in the Video Menu page. Pressing any key on the remote will only cycle between a blue screen and the video menu. Also, the power button the TV will not turn the TV on, but it will turn the TV off. In contrast, the power button the TV will turn the TV on, but when it is on, the power button, like all the others on the remote, will only cycle between the blue screen and the video menu page.
  • Anonymous Jan 25, 2008
    Same thing for me...same tv...same issue...what to do?!
  • Stacylyn Apr 04, 2008
    I have the exact same problem for the same tv
    Sergeant:
  • 291 Answers
Unplug TV for about 2(two) hours, while the TV is unpluged press the on\off button on the TV every once in a while. Replug electricity and try to turn the TV without the r\c, use the on\off button only...If that does not work...u need a tech to look inside..
Posted on May 01, 2008
  • 62 Answers
Call 800-726-4405
Posted on Mar 29, 2008
6ya staff
SOURCE:
How to unlock a key lock of akai tv
This is only a guess but pressing Menu on the remote then up or down to Setup followed by Key Lock to turn On or Off.
Hope this helps..........
Sep 26, 2017 | Akai Televison & Video
How do i fix my akai tv stuck in startup screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Aug 27, 2016 | Akai Televison & Video
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
My TV is stuck on Video with a blue screen. Is my
Change the input to cable or TV. Look in the manual and use your remote to scroll through the menu....
May 29, 2010 | Sanyo DS31520 31" TV
LG 32lc7d lcd tv the work find for about 5min. Then the on screen menu comes on the screen then it gos off the remote will not work what board is it ?
Maybe the remote has some keys that are stuck together on the membrane pad. Take the batteries out of the remote, then turn the TV on again see if the menu problem is still happening. Also check the menu button on the TV see if it is stuck by pressing it a few times.......
If all seems ok but still have the same problem, then the the keypad board in the TV needs to be checked for intermittent shorts or opens. If the keypad board is good then the main board needs troubleshooting. This seems like an EEPROM problem, you may want to test that first on the main board.
any questions please ask....
CWR
Jan 20, 2010 | LG 32LC7D Television
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
No video on our tv
I found in the manual on page 13 bottom, that if you PRESS STOP buttom for 5 seconds of your remote controller then you can see the picture on the interlaced mode again on your TV.
Otherwise you have to connect you DVD to a unit that has progresiv scan, such as an HDTV, some computers if they have an input or to a projector .
I connected my DVD to a projector thru the VIDEO output and put eveything back to normal, and it is working fine now.
System Reset
Open CD disk tray. Press stop key and hold for 15 seconds, screen will appear.
Apr 01, 2009 | Akai DVPS760 DVD Player
Child lock
press&hold DISPLAY button on hand set& VOLUME button on tv front cabinet. or turn on tv setpower switch while pressing & holding volume + & volume- button on front cabinat.the adjust menu is indicated with each parameter on the screen. hope this helps
Oct 07, 2007 | Televison & Video
Akai LCT3285TA 32 in. LCD Television Logo
338 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
