Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Red out of whack
Tv has red screen when i start my dvd player and evrything i watch has a red background.
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 15, 2008
I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
Jul 19, 2010 | Sony DVP-NS50P DVD Player
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
Which channel do i put the tv on, and which do i put the dvd player on in order for them to work together? I have a sanyo flat screen tv and a sony dolby digital dvd player, and i don't know how to get...
You do not put your TV on any channel. DVD players need to connect to a TV with video cables and not a RF cable. This means 3 connection options on how your DVD player should connect to your TV. First, since your DVD player is NOT a bluray player, then HDMI connection is not needed. 2nd, the best choice would be component cables. These are the RED/GREEN/BLUE RCA connector that are on the back of your DVD player. They got into the input of your TV that has the RED/GREEN/BLUE RCA connectors. These are your video connector. Now, you need to connect the audio. Look for the RED/WHITE analog audio connectors out of your DVD player. Connector those to your AUDIO RED/WHITE input of the TV. Power on the DVD player and then power on your TV. Press the SOURCE or INPUT button on the remote for the TV until you see the DVD on the TV....The second option is the connect your DVD player up to your TV with composite video, YELLOW/RED/WHITE cable...
May 16, 2009 | Sanyo DP32648 32 in. LCD TV
Green Screen instead of Blue
Check the picture settings on the tv, if that is not the problem, then check all of your connections (RGB cables+RW Audio) that is HD component, if you have both HDMI and HD component then try one of them, or it may be a switch in the back of the DVD player or TV
Jan 11, 2009 | Miller TELEVIDEO 995 TERMINAL W/ GREEN...
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
Scrambly TV
take a quick peek in the manual and find out where to disable the progressive scan features. may be a button on the back, or you may have to go through the on screen menu to find it. take the disc out and see if you can view what's on screen. or since you said you had a couple of movies that did work properly, put one of those in, start the movie, go into the dvd player setup menu and disable the progressive scan settings
Aug 13, 2007 | Sungale DVD-2026 DVD Player
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
