Question about Hitachi 60SBX78B 60" Rear Projection Television
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
The glass fuse on the board is still good. Tv was powered off and won't power back on. I work on some electronics, but not often in depth. Any assistance would be greatly appreciated. Matt (crippsms@windstream.net)
  • hpbaja Jan 22, 2008
    I have the same problem....I will check the lights...
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Mar 15, 2009
    Novelist:
    Champion:
  • 232 Answers
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Posted on Jan 04, 2008
Hi BMW,
I saw your post and need some assistance with 60SBX78B no Picture or sound I have opened the back and looked at the LED's here is what I found: Red D912 Always On, D940 Always off, When I have some one push the Power D946 & D939 turn on all other green LED's are always on. Any Ideas, I really appreciate it.
Hector Preciado
hpbaja@netzero.com
Posted on Jan 29, 2008
Thank you all for trying to help! I downloaded a factory service manual and traced down a protector fusible resistor #E991 (yellow w/red stripe on one end) near 120vac input on the board. When tested it showed open, I replaced it with a new one part#AZ00109M(protectorCRXT) from sears for $2.16. The picture couldn't be any more perfect short of HDTV. When I initially plugged it in, the power button nor the remote made any LED's light on the board(completely dead by sight & sound. I hope this helps someon with the same problem, and again thanks for all your replies!!!
Posted on Jan 15, 2008
Solicito ayuda para la reparacion de mi televisor hitachi mod 60sbx78b. el cual se daño por un sobre voltaje en la liea AC
el TV actual mente uno lo conecta y los led de la tarjeta prenden e intenta prender pero parese quese fuera a proteccion e inmediatamente se apagan.
e revisado la fuente y la salida horizontal junto con todos los reguladores y aparente mente todos los elementos estan bien. me gustaria que me sujirieran por donde revisar tambien me gustaria que me eviaran el manual de servicio para una mejor revicion Gracias
Posted on Jan 14, 2008
When i power on my TV, it tries to start normally, but when it happends it goes to protection state, i ve been checking the source and the other devices and it seems to be working ok, so i would like you to sggest to me a solution why does it go to protection state... Well this TV had a big voltage pick, cos of a lack of electricity... so what should i do? im going to be careful of your soon answer..
  • Hitachi Master
  • 8,617 Answers
I am taking it for granted that you have tried both remote and button on the set to power it up. I would tend to check out the regulators and Horizontal out put first, Then capacitors in the power supply.
I have an Hitachi TV and it will not come back on. It is about 8 years old. It usually will reset it self after I unplug it, but it just won't come back on now.
Look for a bad fuse on the power supply board. If it looks good, use a voltmeter to verify the various voltages are present on the power supply board. Also look at the filter capacitors for rounded or puffed up tops. They all should be flat on top. If you find any suspicious capacitors, you can get a new board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 13, 2017 | Hitachi Televison & Video
I have a Hitachi HDB70-S tv. It was switched off at the mains and switched back and I now have no picture or sound
If power was disconnected with the set either on or off when it returned (the power) the surge may have got the fuse that is inline with the power cord or even damaged the power supply board in the set.
I would look first at the fuse and take it from there if the fuse turns out to be good.
Apr 30, 2012 | Hitachi Televison & Video
My hitachi plamsa tv won't turn on. It is plugged in but there is no power indicator light. What do i do? is it broken?
Sounds like a bad power supply. You should be able to remove the back of the TV and locate the power supply (look for lots of silver capacitors and a fuse to know its the power supply board) and obtain a part number. Write down any numbers you see on the board or on stickers. Then you can try searching www.shopjimmy.com for the correct part and replace it.
Jul 08, 2011 | Televison & Video
TV screen is black but power button lights up. No
you need to open the tv up and take out the internal fuse or fuses...go and get the right type of fuses...(the fuses will be made of glass and the same size of a plug fuse) DO NOT USE PLUG FUSES....if that fails then you need to take it to the tv repair man
Apr 28, 2010 | Hitachi 57TWX20B 57" Rear Projection...
Got a Hitachi rear projection model # 50ux58b. Kids been playing the Wii and all of a sudden no power. Course nobody knows nothing. You know the story. Anyway Fuse and cap probably need replaced. Any idea...
the three guns that the lenses drive operate at 28kv.
there are very high and dangerous voltages in a tv set.
you can look for the fuse main pc board by the power cord..if it is black,there is a major short.if it is just barely blown,change it.
the fuses are 3ag glass type and just pop in. use a set of rubber gloves and insulated pliers.. tvs are DANGEROUS
Jul 04, 2009 | Hitachi 50UX58B 50" Rear Projection...
HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Oct 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 42HDS69
Yes there is a fuse in most of the sets for protection that might either be a glass fuse or a fuse soldered to the board. If the fuse is intact suspect a fault on the power supply board where you located the internal fuse. Hope this helps.
Sep 23, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50DX10B Power issue
Rollo, broken solder connections either in low voltage or sweep section of the board, probably in the horizontal out put area but could be anywhere. If you want to attempt the fix the board has to come out and you`ll need a bright light as well as a good magnifying glass to find the broken joints and then re-solder them, Be certain your tv`s AC cord is removed from the wall outlet before doing any soldering, good luck, BMW Rider
Dec 13, 2007 | Hitachi 50DX20B 50" Rear Projection...
Hitachi 60ux58b projection tv
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Aug 18, 2007 | Hitachi 55FX48B 55" Rear Projection...
Televison & Video Logo
883 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
