Back to:
Tags:
Sharp R-308J 1100 Watts Microwave Oven
Installing the keypad back together (by 2 users)
posted by Samijoe on Jan 04, 2008
i took apart the keypad to remove a roach from the display window now none of the keys will work
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by johnprieest, posted on Aug 09, 2008
I had the same problem with a bug in my display. I took the panel apart and put it all back togther as displayed. When I power it up I get the flashing 8's, but nothing works on the keypad. Any ideas?
Best Solution
posted on Jan 13, 2008
Inappropriate (40)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2983 votes
You must clean the bottom rear edge of the LCD glass, both sides of the "zebra" strip, and the contact area of the circuit board with high grade (50% or better) isopropyl alcohol and a clean cloth.
I've attached a photo here, but if it doesn't show up well, you can find it at:
http://207.234.249.73/mwd/r308jw_r308js_controller_cleaning_exp.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on installing the keypad back together:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
Have a kitchenaid superba part no. 4450786A with the probe...
Microwave Ovens
I have a Sharp Micro Wave Model R 1512 F that the start...
Microwave Ovens
removing an ols microwave model jvm48 -need help in...
Microwave Ovens
Hi there, my microwave wont stop beeping in all kinds of...
my keypad over heated and i lost some of the keys. i have...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
