Brother HL-2040 Laser Printer
Problem for Brother HL-2040 Laser Printer
My brother HL2040 printer shows
By gmsanabria on Nov 03, 2009
my brother HL2040 printer shows out of paper when it has paper.
Solution #1
posted on Nov 03, 2009
Not Rated)
Soulvisitor
Rank: Guru  Brother Computer Hardware  Expert
Rating: 88%, 2367 votes
try turning it off, diconnect from computer.. Leaving it disconnected,turn it on, when green light indicates it is ready, tap the green go button 5 times real quick.
this should print a self test, if that works as I suspect it may, it is because the document that the computer is trying to print is not the same paper size as set on printer or trying to print to wrong trat ie bypass, ensure paper type is set to plain too.
If a test page tried to print but then came up out of paper, check there is nothing stuck in paper path (rear door?) and if game, give rubber feed roller a clean
Chances are and I;ll lay me bet 10-1 that paper size of document is different than tray setting and placing a sheet of paper in bypass(slot at front) is what your machine is trying to say to you. see how ya go..cheers
Was this helpful?
Yes
No
Popular Solutions for Brother HL-2040 Laser Printer
Questions and Unsolved Problems for Brother HL-2040 Laser Printer
Do you recommend Brother HL-2040 Laser Printer?
Answer
Answer
toner leaks out over the page - makes an irregular grey film
Answer
printer output paper printed ok but paper has been ruffled (like sea waves)
Answer
I have just replaced the toner cartridge because the light was a constant yellow (not blinking) but... (More)
Answer
The toner light on my HL-2040 is on and won't go off, thereby locking up the printer. I've replaced... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
