Goodman GMS90703BXA Heater
Problem for Goodman GMS90703BXA Heater
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
By Frailerboy on Nov 03, 2009
I'm considering installing a Goodman LP Gas furnace, a 95% two stage gas valve with either a two speed or variable speed blower. I have two problems: I'm not certain of the sizing as several contractors have different estimates, and I don't understand how either furnace works, and the contractors can't seem to explain the process.
My house is a double brick, (two layers brick, three inch air gap between, roamed with open cell foam.) Inside area, 2,300 sq. ft., outside, 2,600 sq. ft. Currently using a 140,000 btu inpurt, 120,000 btu output, 80% afue Luxaire, about 12 years old. Furnace completes two cycle per hour at 20 degree outside temp, heat cycle five minutes. At very low temps, c. zero F, furnace runs about half the time. Estimates on two stage systems range from an upper value of 105,000 BTU to 90,000 BTU, I'm assuming this is input BTU. My windows are ten year old Lowe"s "Survivro" vinyl, basement ceiling is insulated. Last year had an infrared scan done, result, house is "substantially" efficient with a couple weak areas where foam apparently didn't get applied.
Again, my questions, what is the proper size furnace in input BTU, and how do the variable two speed blower and variable speed blower models work?
Thanks for you help...
George
Solution #1
posted on Nov 03, 2009
Not Rated)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 87%, 473 votes
Consider a variable output system like a Carrier 58MXA or an American Standard AUX unit. This way the unit will ramp up or down based upon the heat required. These units have two or three Btu outputs so they will modulate to find the right range. Yes they will cost more than the Goodman units but will save you gas dollars for many years to come. Goodman is a good Builders unit but look to fuel economy as prices of fuel increases. Right now your furnace is is using 60 Btu's per square foot. Are you located in Alaska? Here in Vermont if we figure 30 Btu's per square foot, that is one very drafty home. Ask to see their Manual J heat loss. If they say "What" time to move on to another heating contractor.
Was this helpful?
Yes
No
Solution #2
Not Rated)
knthms5
Rank: Wiz  Air Conditioners  Expert
Rating: 84%, 30 votes
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Was this helpful?
Yes
No
Popular Solutions for Goodman GMS90703BXA Heater
Questions and Unsolved Problems for Goodman GMS90703BXA Heater
Do you recommend Goodman GMS90703BXA Heater?
Answer
Answer
i need a service an parts manual for a dayton 3ve50 an alsowhere i can buy parts and alocal repair... (More)
Answer
When the pilot lights the furnace the fan comes on and the fire goes out
Answer
my 55000 to 85000 btu propane heater will not fire up and stay running, tank is full,push button and... (More)
Answer
how do i switch the heating on.i have a baxi bermuda , it has a dail on the side off it but not sure... (More)
Answer
i have a 1997 goodman 3.5 ton outside gas, self igniting heater. the led beep is 1 then a 2 then a... (More)
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
