Acer Aspire 5500 5570-2609 Laptop Computer  PC Notebook
Problem for Acer Aspire 5500 5570-2609 Laptop Computer (AS55702609RTL)...
Hi, i have an Acer Aspire 5730ZG notebook not older than 1 year.
By cihanerdil on Nov 03, 2009
Hi, i have an Acer Aspire 5730ZG notebook not older than 1 year. It has started to shut down immediately (without any warning) since a week when i'm running a program or a game that needs much cpu usage. I think it's cause of overheating but why since a week? When i check the notebook surface it's hot (even touchpad). The room where i use my notebook has 21-22 °C temperature. The strange thing is before shutting down the battery indicator led is orange and starts blinking. Actually this is a charge warning. I mean when the indicator is orange and blinking it means battery is low and needs to be charged. Notebook is under warranty but i don't wanna send it to the service cause i sent it before for a display preoblem and got back after 4-5 weeks. Any ideas/solutions?
Comments:
Nov 03, 2009
- Thank you for replying, i forgot to add something: After shutting down immediately, when i try to turn on my notebook, i get an error after seeing windows loading animation: c000021a Fatal System Error written on a blank blue screen. My OS is Vista Home Basic.
Best Solution
posted on Nov 03, 2009
Very Helpful)
parrotheadpc
Rank: Guru  Acer Computers & Networking  Expert
Rating: 89%, 675 votes
You may have a couple of issues here....first is the power block and battery. Run the laptop with just the battery and just put a browser window up and see how long it runs and how stable it is. The take the battery out and run it just on the charger brick, see if it shuts down on you. If the unit shuts down both times regardless of the power supply, then I would suspect the processor is giving the shut down signal because it is getting too hot. The overheating condition can be caused by a number a factors, the most common is dust dirt and debris in the cooling grills and heatsink. The first thing I would do is get several cans of office supply compressed air and using short bursts, blow out all grills, compartments, the optical frive...anywhere you can get the nozzle in, use short bursts so you don't accidentally spray any condensation vapor that may be released from the can during extended spraying. The next thing to do is remove the heatsink from the laptop and replace the thermal paste or if it has cooling pads, clean around that area and make sure all dirt is cleaned and removed. I will include a link below to your service manual. It is 25 MB in size and is in PDF format. It is free to use, copy and print if you want. Look on Page 75 for heatsink removal, it is under the large accesss panel on the bottom of the laptop, remove the screws that hold the panel and pry it up with a screwdriver. Good luck.....
http://tim.id.au/laptops/acer/aspire%205930%205930z%205730z.pdf
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thanks a lot. " - cihanerdil
Solution #2
Not Rated)
dwane4444
Rank: Guru  Computers & Networking  Expert
Rating: 88%, 83 votes
If the machine is under warranty then your best option is to return it, as anything you do to try and fix the laptop will probably invalidate the warranty and you will end having to pay to get it fixed!
Was this helpful?
Yes
No
Solution #3
Not Rated)
guru jee
Rank: Wiz  Computers & Networking  Expert
Rating: 83%, 41 votes
to be very honest to u
this heating problem culd be bcoz of an internal wiring, so i wuld really suggest that send it to the service people as it is in warranty cuz if u dnt do this it can lead to several burns and may void warranty, so y take chance.
one suggestion i wuld wanna give u is tat there is a place on the back of the laptop which is the heat outlet, make sure that is not blocked while u r using it, clean it with a brush if needed. i am talking bout the one from wher hot air cumes out.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5500 5570-2609
Questions and Unsolved Problems for Acer Aspire 5500 5570-2609
Do you recommend Acer Aspire 5500 5570-2609 Laptop Computer (AS55702609RTL) PC Notebook?
Answer
Answer
Just recently I format my laptop (acer aspire 5570).When I tried to install the sound driver... (More)
Answer
i am a violinist....i play only rock and jazz on my violin(acoustic)....so at this moment i'm just... (More)
Answer
My Ipod touch is not recongized...works with other computers and laptops....any suggestions? Have... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Newbury, OH
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
