Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Needs instructions to remove the front panel to replace the microswitch near water dispenser arm
Kenmore 5553 2000 model
  • Anonymous Jan 04, 2008
    Need instructions to remove the front panel to replace the microswitch near the water dispenser arm. Is there a wiring diagram available for this kind of unit?
  • janeagrs May 08, 2009
    how to remove panel from water dispenser to clean behind it.
Kenmore model#10658562891 side by side refirigerator.
Need instructions on how to remove front panel to check or replace the heater that keeps Ice from freezing in the Ice chute.
Posted on Feb 18, 2008
6ya staff
SOURCE:
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Side by Side water dispenser would not stop
You will need to replace the switch. Here is the part to order.
To replace the switch:
Here are the basic instructions: " 1. Unplug the refrigerator power cord. 2. Remove the overflow grille from the housing. 3. Unsnap front cover at the bottom of the housing. (You'll need to insert the tip of a flat blade tool into the slots molded into the bottom edge of the facade and twist or pry out,you may want to use some type of pad to eliminate damage to the door panel). 4. Disconnect the front cover switch harness connector and set the cover aside. 5. Disconnect the power wire harness connector (BL/BK and W wires) 6. Disconnect the flapper door heater wire harness connector (if one is present). 7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart."
Oct 31, 2012 | Whirlpool Refrigerators
Continuous flow from water dispenser
With GE it could be a bad water valve, bad microswitch that actuates the water or could be a bad main control board. You can diagnose the valve by simply pulling the wire harness off and turning the water on. If the water starts to flow with the power removed from the valve then the valve is stuck and needs replacing. If the water stopped with the power removed, check the valve's wire harness with a volt meter and see if 115vac is being applied. If so then the switch or the board are bad. You can check the switch by setting your meter to continuity and checking the com part of the switch to either the no or nc part. One should test good for continuity, the other not and with the switches buttong depressed the exact opposite. If the switch test good then the board is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | GE Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser
This sounds like the microswitch that is activated by the paddle is sticking . If all the other functions appear to work ok ?? Does this particular model have an ice and water dispenser ?? Does the ice behave in the same way ? if not then i would suggest that the water valve is not closing and needs replacing instead of the microswitch
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fabric softener tray
If this is a front load youll have to take the cover panel off the washer ,to get access to the left side where the dispenser is.The cover top panel has 2-3 screws at the back of the lid , remove them.Push the panel back as it will slide backward to remove it.Now observe the dispenser arms that control the actual water flow direction.Run the washer ,while watching this arm making sure it is not slipping in one spot.Because it probably is.If so replace the dispenser arm assembly.If this is a top load well I just waisted alot of typing here.Let me know. The model # should be listed.....
PLEASE RATE THIS!!!
Jun 22, 2008 | Whirlpool Washing Machines
Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
540 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
