The reason for F02 error is due to something stuck inside. Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business
Thanks for contacting Fixya.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore Elite 45986 Front Load
My front load Elite is stuck in the rinse cycle with the 1:05 time remaining. I cannot get it to do...
(More)
My front load Elite is stuck in the rinse cycle with the 1:05 time remaining. I cannot get it to do anything. How do I get it to continue with the rinse cycle and complete? Thank you
tried to spin only and the f27 error came up. the machine will not just spin i have an aqua steam 9...
(More)
tried to spin only and the f27 error came up. the machine will not just spin i have an aqua steam 9 kg machine
washer starts fine. then this FH messages stops it. i push cancel then start and it runs for a few...
(More)
washer starts fine. then this FH messages stops it. i push cancel then start and it runs for a few then the FH message agian. FH means water inlet problem, but the washer is getting plenty of water. HELP!!!!
