Question about Goodman GMS90703BXA Heater
Model GMP100-5-REVA light blinks 4 times fan runs constantly
  • 1,420 Answers
You could have a limit switch that opened. On the reverse side of the furnace access panel there will be a diagnostic chart indicating what 4 flashes indicate. If it is an open circuit, why is it open? Did the unit get too hot and why? Unless you have the diagnostic capabilities, call a professional.
Posted on Jan 04, 2008
My electric furnace constantly runs.. no cold or hot air blowing through the vents.. red LED light blinks 4 times saying limit switch open.. how do I fix the problem?
You'll need to replace the fan limit switch. This little switch is what tells your blower when to kick on and when to shut off. It's stuck open.
Mar 05, 2015 | Heating & Cooling
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Blinking 4 times red .... can u help? sony wega.
There are a number of forums that deal with the error codes for this and other models---if you want to find the answer for yourself Google the full model number with "4 blinks" or "error codes" and if you cannot find the answer leave me a note here and I will research it and find out.
Keep in mind the blink code is just a general indication of what is wrong---it does not mean replace part XYZ and set will be working again.
May 20, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
Installed a Graphics Card on my Emachine. Made sure it is in the PCIX slot correctly and seated right. I also installed a Power adapter cable (20 PIN - 24 PIN ATX) to utilize the other 4 pins for use with...
Sounds like there isnt enough power even with the adapters your powersupply cannot give you enough sustained power to run the system if you take the card out does it boot normally? even just disconnecting the power to the card?
Mar 26, 2011 | E-Machines W6409 (7234) PC Desktop
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Goodman GMS90703BXA Heater Logo
344 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
