Question about EnGenius DURAFON1X DuraFon 1X System Phone
EnGenius DuaFon 1X
When you turn the cordless on it say connecting line then no connection. You are not able to recieve calls or make calls. I switched the phone lines to make sure the line was good and it is. I work at a motel and nobody knows how to fix the phone. Can you help?
  • hafners Jan 19, 2009
    I can't talk through the phone but I can hear.
  • Anonymous May 07, 2009
    I have the same problem and I want to deregister my phone so I can register my phone but now it says it can't find the base. Why not?
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Posted on Aug 11, 2009
Deregister handset then reregister it
Posted on Mar 05, 2008
You may have to UNregister the set then reregister it
No and we have two phones and neither of them can hear the incoming call yet they can hear us. Nothing happened to the phones they were working and then they did not.
Not likely defective, just need to be reset. If I understand correctly, no ring with an incoming phone call, but the intercom feature works fine. The ringer on the handsets is either "off" it will say no ringer or the base station is not communicating correctly. Intercom is handset to handset. Phone calls pass through the base station first. Of course, check the base unit: power on, phone line plugged in, antenna attached. Then try the phone line to check for dial tone with a regular, "old" analog telephone. If you are using these with a PBX, you must have an analog line installed.
Jul 05, 2014 | EnGenius DuraFon 1X-HC Long Range...
Engenius troubleshooting
Hi..does it have a speaker phone on your reciever..try that if that works..maybe the ear speaker is bad..I have a friend with the same problem..and her issue is she droped the phone in the sink..got it wet and hers did this...it could not be fixed..
I have a phone it recieves calls but can't make them it was working until 2 days ago
Several things can go wrong. Do they need to dial an extension to access an outside line? Make sure they know this. Also, make certain to remove any area code in the menu settings. The phone could be trying to make a call, yet it dial the area code each time and screws up the PBX, so no outside line. There are more possibilities, but they require on site tests.
Jun 09, 2014 | EnGenius DURAFON1X DuraFon 1X System Phone
1 acres =
One acre is about 4047 square meters or about 43,560 square feet.
Feb 20, 2014 | EnGenius FREESTYL1 Slim Design Long Range...
Does Uniden 5.8Ghz cordless phone with 2 speakers need land line connection for its base unit?
Yes,It requires a Landline connection to its base unit to make calls and recieve calls.
Thank You
Aug 16, 2010 | Uniden 5.8GHz Cordless Phone
Engenius 1X phone
William,
It may be simpler than you think. Have you tried pressing the same button you press to make a call to retrieve the second caller? By pressing the button repeatedly, you will switch from call to call unless you have conferencing from your dial tone provider. If this doesn't do it, let me know. Please, calls are important and not to be lost through new technologies.
Feb 18, 2008 | EnGenius DURAFON1X DuraFon 1X System Phone
EnGenius DURAFON1X DuraFon 1X System Phone Logo
853 people viewed this question
Top EnGenius Lands Phones Experts
Eric Sutherland
John L radiodude365
Bill Boyd
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
