Hi Thanks for using FixYa. If your
dishwasher leaks, check these: Main
tub seal Note… If the
main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you. But if
your motor is mounted horizontally, the pump isn't serviceable--you need to
replace the entire pump and motor assembly. The main tub
seal is beneath the drain impeller. It prevents the water in the dishwasher
from leaking out near the shaft of the motor. To get to the seal, which is
inside the dishwasher, remove the: Lower rack Spray arm Spray arm
support Wash/drain
impellers Then pry the
seal out of its housing and replace it. Door gasket or
seal Over time,
door gaskets and seals harden and lose their ability to seal properly. You
can't repair the seals. You need to replace them if they've begun to leak. Water-inlet
valve The water-inlet
valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak.
Tighten or repair/replace these as necessary. The
water-inlet valve could mechanically stick open. When that happens, the water
continues to flow into the dishwasher, which then floods your kitchen. Turn off
the water supply to the dishwasher, and replace the valve. Hoses Behind the
lower access panel on your dishwasher are several rubber or plastic hoses. If
the leak appears at a connection, try a new clamp. If that doesn't work,
replace the hose. Please do rate the solution
if the issue is resolved or else revert for further assistance. Thanks Rylee
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17482 / 17484 /
I have a Kenmore Elite dishwasher and the under counter mounting hardware/bracket has broke. It...
(More)
I have a Kenmore Elite dishwasher and the under counter mounting hardware/bracket has broke. It seems that shops don't carry these parts. Is there a alternate fix for this problem?
I have a Kenmore Elite Dishwasher that is 3 yrs old, which cost $1000. On the top dish rack one of...
(More)
I have a Kenmore Elite Dishwasher that is 3 yrs old, which cost $1000. On the top dish rack one of the splines burst open, almost like it couldn't withstand the heat. I figured this would for sure be covered under the 5yr rack warranty, when I called they said it was but since it is 3yrs old the customer must pay the labor fee of $129. The rack itself only costs $104, and what labor is involved in pulling a rack out and putting a new one in? Does Kenmore not have a defective parts return center where you get an RMA number return your rack, once reviewed for warranty purposes they send you a new rack. I feel like I am being scammed out of money for a clearly defective part.
