Question about RCA P52930BL 52" Rear Projection Television
Screen went black, no picture
RCA Projection TV, Model # P46770CK; Service # P46770CKLG1. We were in the middle of watching tv and the screen just went black. There is still sound, but no picture so I'm guessing it's the picture lamp. The TV is 13 years old and we have never had any problems with it and I don't want to spend a lot of money fixing it, nor do I want to purchase a new tv right after all the money I just spent during the holidays. If it sounds like the picture lamp do you know if it's easy to fix? My husband loves to fix electronics, do you know where I would purchase a part for it? Is it worth fixing? Any help would be appreciated. Thanks, Michele
  • Anonymous Jun 30, 2008
    Turned on TV sound no picture
Where us the r4703 resistor located at is there a schematic for it somewhere i can see?
Posted on Jun 30, 2008
  • 373 Answers
A clue to what is wrong is by looking from the back (taking the back off) and looking to see if the three picture tubes have any yellow glow at the bottom of them where the three identical boards are located on each tube.. If you have no glow there you possibly have a resistor R4703 open. It is a 3.3 ohm resistor and feeds the voltage to the filaments in each tube where the glow is suppose to be. If you do have the glow the problem could be much more complicated. Another to check is to see if the menu comes up on the screen. You could possibly be in the wrong input mode, Check your input mode with the input button on the remote The number R4703 is a location number to identify where the resistor is. This is all I can tell you that would not require much more complicated procedures requiring a tv repairman to look at it. If you have an ohm meter you can check R4703 but it must be checked out of circuit. (or at least one leg loose) Hope this helps
Posted on Jan 04, 2008
6ya staff
SOURCE:
Rca rear projection tv has black screen and beeping
Are you sure the model number listed here is the one on the back of your set? This older model listed here should not "beep". A lot of questions here get posted with wrong model number.
Dec 23, 2012 | RCA P52937 52" Rear Projection Television
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
RCA 62" mod p46770ck need
Now I know the rest of the story: After I went to see the TV I was told it had happened after a storm the next day the set was dead. She had already recieved the insurance money. She said she did not want to spend much money on it as she obtained the set at a garage sale for 60 bucks 6 years ago. As I looked into the circuit board I noticed evidence of water damage and looking up the case and on top, yup, thats why she got it so cheap. I do think it is lightly damaged. As a grandmother of a close friend I didn't Intend to charge her but she gave me some bucks and the insides of the tv. I'm sure their isn't much time on it. If any one wants some parts on a 1993 RCA mod p46770ck (48" screen) contact me thru snailmail @ Whiskers, rr1bx57a zip 64632 Include your ph.# and I will call you. (I don't use the computer every day)
Jun 27, 2008 | Televison & Video
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
RCA Projection TV will not turn on
hey,
I just fix my RCA p46770ck with that faint click sound when you try to power on. It was the HV splitter for $74.and change. after a long hunt to find the source of the problem I did what my local appliance store said to do replace the hole board for $275 luckily I was able to return that because it did nothing different than my board/module click.... click.... clickclickclickclickclick turn on you peace of @#%! any way if you unscrew the back cover off you'll see a black box at the top left corner with 4 red wires going to it groped 3 and 1. The 1 is your HV (High Voltage) supply and then gets split to each tube. Oh you should of unplug the tv before you touch any thing HV is 30,000 volts after you unplug you should push the power button to get ride of all voltage. please feel free to contact me at [email protected] for any Q: I can get part numbers or help in any whey i can
Nov 06, 2007 | Televison & Video
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
