Question about Uniden TRU8885 Digital Answering Machine
Constant incoming call indicated
I have a Uniden PowerMax 5.8GHz cordless phone. It has a base and two handsets. All of them show "Incoming Call" most of the time, and mostly when there is no call. I have added a DSL line filter with the idea that there may be high frequency interference, even though we do not have DSL. This did not help. The result is that both handsets do not charge. Replacing the batteries was not needed since they do not charge when there is an incoming call. Perhaps it needs DC isolation? The only way I can use the set at all now is with the ringer turned off.
  • Anonymous Mar 28, 2014
    Handset and phone volumes are set high. INcoming calls do not make a sound.
    New Friend:
  • 136 Answers
This is a problem only the company can help you with maybe they can return this one and give you another just call 18002971023
Posted on Mar 30, 2008
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
I have a uniden power max 5.8ghz phone and can't turn on the ringer it will not ring when a call is incoming how do I turn on the ringer ?
The procedure varies from model to model. Since you neglected to specify the model of your Uniden Powermax 5.8GHz cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 30, 2011 | Uniden Cordless Phone
Does just one handset works for call or are they suppose to work both hat the same time?
DECT cordless phones associated with the same base unit will all ring when an incoming call is recived, however only one handset can answer the call.
Unlike a corded phone, another handset cannot "join" an ongoing call, but the call can be transfered between handsets - your phone's manual will tell you how.
Nov 04, 2009 | Uniden Cordless Phone
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
My GE #28223 phone will not let me answer incoming calls at times
This happens when the base somehow gets de-registered from the handset. There are two ways to solve this.
Disconnect the base from the electrical outlet for about 5 seconds, then plug it back in.
The other way to solve it is to re-register the phone with the base. Consult your user manual to follow the process. to do this.
Feb 14, 2009 | Uniden Cordless Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Uniden TRU8885 Digital Answering Machine Logo
93 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
