FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
Where to connect what on motherboard
posted by gardnho37 on Jan 04, 2008
Need to know where to connect what cables when installing hard drives, DVD Roms, PC light, etc.
Comment by gardnho37, posted on Jan 06, 2008
Thank you smeags!
You reply helped a lot. I don't have a manual, as this computer was bought second hand without any type of reading material. Oh well. Nevertheless, I do recognize the case cable and the pwr location on the motherboard, so thanks bunch for you help. Appreciate it. Ally
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2008
Helpful (85)
smeago1
Rank:Wiz Wiz
Rating: 83%, 98 votes
Very generic questions so lets see if i can answer as best as i can. hard drives and dvd are very similar principles (see below)
hard drives comes in SATA or PATA. If its a SATA then there should be small red connectors that you should plug the HD in on the motherboard while PATA or IDE drivers should have white connectors. They are wider in width of the cable containing about 24 pins. The motherboard would also call out SATA1,SATA2 etc so you know its the SATA plug. Likewise for IDE drives.
Regarding power switches, on most motherboards there should be a set of pins at one corner of the board with tiny little letters pwr next to it. You will need to connect power switch cable from the case to the motherboard.
I highly recommend you read the manual that comes with the motherboard to see where it is located.
good luck
smeags.
Rating Locked! (?) gardnho37 has rated this solution as Helpful
Solution #2
posted on May 04, 2008
Not Rated (0)
daisymol
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
my asus socket939 driver cd loss, so do you help me for installing for inetalling the drivers in my computer
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Compaq Motherboard HP PavilionCongo Motherboard Skt462 Via KM13A AMD 2 Dimm Motherboards HP (KZM-6120) Motherboard ASUS P4GE-MX Motherboard ASUS Intel 440BX Chipset P2B Motherboard ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard ASUS P5N-E SLI Motherboard
Can you Help with these Motherboards problems?
Intel Motherboard
Latest Bios For The E210882
Hi, I am looking to update my... Answer This...
ASUS P5RD2-VM Motherboard
Why does my comp didn't run...
This is my mainboard specs... Answer This...
Motherboards
max memory per slot
i would like to know the max... Answer This...
EliteGroup (ECS 915PL-A2) Motherboard
add sata HDD
Hello sir, I want to add new... Answer This...
Motherboards
PCC266 = PC400?
is PC400 compatible with VIA... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
