Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
No cold water on cold settings
When I set the washer on cold/cold the clothes feel warm when they are finished with the washing cycle.
    Scholar:
  • 64 Answers
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Posted on Oct 20, 2008
6ya staff
SOURCE:
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
Cothes are being put on a 40 wash but coming out stone cold is there a way to check if water is heating as no fault is flashing up on display
I would expect the clothes to be cold after the cycle is finished, as it will have completed at least 3 cold water rinses, so I do not think you have a problem.
If you want to check if the heater is working o/k, then select a hot wash programme, say 90 degrees, and feel the door glass after 30 mins or so, it should feel warm , and if the heater is not working, then normally the washer will not complete the programme.
Dec 01, 2010 | Washing Machines
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
What is the HC code for the washer . It comes on after the wash cycle is finished.
After replacing the part to fix the F1 code, the washer (Oasis he) now comes up with a HC code. Also, even though the cycle is set for warm/cold, the clothes are coming out hot at the end of the cycle...and the cold water is hooked up and on. Any suggestions?
Sep 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
136 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
