Question about CD & DVD Burners
Lost DVD Driver in Windows XP Pro!
Not Showing in My Computer, How do I get it Back?
SOURCE: can not read DVD k16d from vgn-n130g with XP pro
try using this Microsoft tech article to resolve your issue:
Posted on Feb 01, 2010
0 characters
1 Points
Samsung i386 dvd burner is not opening when i change windows xp to 7 pro
Do you know if the software for the burner is accepted by windows 7, and does the computer recognize the burner as being installed ?
You may have to update the driver for the burner to match windows 7 requirements.
Sep 25, 2012 | Samsung CD & DVD Burners
I still can not get the Laptop running Xp Pro sp3 to see the CDRW/dvd combo drive. I followed all of the previous instructions but when I get to the Place where I'm supposed to delete Upper Filters. There...
make sure that the cdrw-dvd rom is getting enough power test all leads that are attached to the cd-dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Apr 01, 2011 | Dell (8W007-A01) for Latitude, Inspiron...
Would like to install drivers and software for my LG Potable Super Multi Drice GP08NU6W on another computer bot lost the CD that came with it. Where can I download the software/drivers. I am on Windows XP...
you wont download it. Do the fllowing step.
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' on it your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 26, 2011 | LG ELECTRO GP08NU6W Super Multi Disk drive...
I removed vista and put an original licenced windows xp pro but the dvd does not work and it disappeared from the bios
Vista is proprietary, you need to go out and find the correct driver for that CD-RW/DVD-ROM for that Acer PC.
Jan 29, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
How do I get the drivers needed to make the DVD Movie Write DC3000 work on Vista?
HP does not make a Vista driver for your device. Here is their driver page for you unit:
When you plug it into your PC, it should auto-discover it. While connected to the internet, reply YES to let windows search for a driver at MS. If it finds one, you should be ok. If it can't find one, I'm afraid it's not going to work.
There are drivers only for Windows XP and Windows 2000 Pro.
Dec 03, 2010 | HP DVD Movie Writer Dc3000 DVD+RW Burner
Drive recognized by BIOS but suddenly not XP PRO SP3
make sure you have reinstalled all drivers for all of your drives and what not. If you have, are there any notifications in Device Manager? To get there, right click on My Computer, then click Properties. Click the Hardware tab, then Device Manager. Hope this helps, or let me know what you find in Device Manager.
Apr 22, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Cant even READ DVD
the XP driver really should work appropriately. I might assume that the drive is damaged (which happens to me frequently with older DVD drives).
Oct 30, 2008 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD Burning Problem
To reinstall the driver RIGHT Click on My Computer - select Properties - select Device Manager - RIGHT Click the DVD listing - select Update Driver (have your disk handy).
Good luck.
Apr 19, 2008 | NEC ND-2500A DVD±RW Burner
Windows XP Pro - LG GCC-4243N combo drive not seeing data on disks
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
Jan 12, 2008 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
CD & DVD Burners Logo
258 people viewed this question
Top CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Are you a CD and DVD Burner Expert? Answer questions, earn points and help others
