Dryers
Problem for Whirlpool Dryers
Generic problem for all Whirlpool Dryers
Dryer blows limit fuses, have replaced bef...
By rembgood on Nov 03, 2009
dryer blows limit fuses, have replaced before.
Best Solution
posted on Nov 03, 2009
Very Helpful)
jballiett000
Rank: Guru
Rating: 94%, 16 votes
The vast majority of dryers that blow high limit fuses have the same problem: Lack of airflow. If anywhere in the venting system for your dryer is restricted your dryer will heat up too hot. The excessive lint in the filter, a clogged dryer vent hose, the vent within the house, even within the dryer itself all are places where a restriction could occur. Check all of these for being restricted. Also make sure if you have a flexible hose between the dryer itself and your dryer vent on your home, make sure it is not crushed when the dryer is in place. This will cause your limiting fuse to blow very quickly.
When you remove the hose from the back of the dryer you can check that the dryer itself has decent airflow by starting the dryer on the fluff/no heat setting. This will give you an idea whether it is restricted inside the dryer or not. If you even have a hint that it is not putting out the air it should, have it cleaned (or if you are mechanically inclined do it yourself just make sure the dryer is unplugged).
Then have the dryer vent system cleaned. Replace your high limit fuse and you should be back in business.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if... (More)
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
inside light will not come on, kenmore elite he4 electric dryerwill not run, beeps three times when... (More)
Answer
my crosley dryer will not start when pushed, the timer starts, but no power to start dryer
Answer
my whirlpool AWZ2303 tumble dryer only seems to be blowing cold air can you help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
in San Mateo, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
