Copiers
Problem for Sharp Copiers
Generic problem for all Sharp Copiers
Reset drum counter on Sharp AL-1644
By darren_frist on Nov 03, 2009
Hi, is it possible to reset the drum counter on a Sharp AL-1644? Thanks
Comments:
Nov 03, 2009
- Hi unfortunetly no good. It must be different on this make? I've tried all cominations of button presses to get into service mode, so far to no avail. Any other ideas?
Nov 04, 2009
- I think this problem is going to beat me. I have tried C, density, C, density. #,*,C,*. C, auto, C, auto, and just about every other comination I can think of, again to no avail. Drum purchase here we come :-(
Nov 23, 2009
- Fantastic, the last code #, interupt, C, interupt, worked first time. I've tried bashing every button combination I could think of, but didn't try that. Thanks again!
Best Solution
posted on Nov 03, 2009
Very Helpful)
wheatlandsvc
Rank: Guru  Office Equipment  Expert
Rating: 93%, 83 votes
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Comments:
Nov 03, 2009
- ok how about #, *, C, *
pound,star,C,star
Nov 03, 2009
- Or Clear, Auto, Clear, Auto
it should be one of these for sure.
Nov 20, 2009
- A friend looked this up and says it is #, interupt, C, interupt
You can try entering that sequence and see if the display goes blank then you will know it works for next time, assuming you have already bought the new drum. Let me know if it works so I can add that to my data base.
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you. " - darren_frist
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
when i want to print anything with a pic or color, it seems to take forever to spool up.
Answer
i don't have a list of service codes. I do not know what a sc05-52 code means?
Answer
I am getting a paper mis feed at the fixing unit. It never actually enters the unit, after it leaves... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
