Question about Whirlpool Duet GHW9150P Front Load Washer
Ripped door seal
The boot inside the door is ripped...again!  this is the 2nd time in 5 years.  I was only washing a small blanket.  why is this happening?  do I need to expext a $100 repair every 2 or 3 years?  thanks for any help.
  • 283 Answers
It's usually not a good idea to wash single items in a front loader. This is because it can't properly balance the load. Either the item won't come out dry enough or if it does manage to spin the machine will shake violently until one of the shocks comes loose. When that happens the tub tilts down and to one side twisting the boot.
Posted on Jan 05, 2008
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Feb 19, 2014 | Maytag Washing Machines
Wbvh5300k2ww washer leaking
door gasket or door boot or the door bellows, it can be referred to by any of these 3 names
Nov 11, 2012 | Washing Machines
Water leaking from front door
Check gasket for rips or damage. Replace if necessary.
Clean gasket after every use. Wipe with a bleachy rag. Use only HE detergent in small amounts.Dog hair, etc can get stuck in the gasket causing a small leak. Oversudsing can also cause leaks.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leak/boot tear in whirlpool duet washer
The front door seal is referred to as the "bellow". They will wear out with age and may become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer providing a good seal, it must be replaced. This will cause water to puddle under the front of the washer and inside the cabinet. The following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the part number is 8182119.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. In addition, overloading the washer can contribute to premature wear and tear on the bellow which can lead to rips, tears and possible dislodging from the bellow clamp seals. Always follow the manufacturer's recommendations for loading in your owner's manual.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
My GE washer has a small cut on bottom door seal, is there a glue or seal that can be used to make repairs rather than purchasing a new door seal
Find a Epoxy glue that will hold up to the rubber or plastic that this is applied to for it may melt the rubber if not the correct type Two Parts Epoxys are good!
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Frontloader door keeps breaking
Call your retailer directly to make you whole.
Video tape the events and send an email to Kenmore.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore 44102 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Whirlpool Duet GHW9150P Front Load Washer Logo
179 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
