Question about Mitsubishi WS-65905 65" Rear Projection Television
How do i get 1080p
I purchased a blue ray dvd player and want to see the movies in 1080 I'm only getting 720p
How did you get 720p? I have having trouble viewing anything above 480p. When using my directv HD DVR, the screen goes black when it tries to show anything above 480p. Is it the tv or the DVR?
Posted on Jan 07, 2008
  • fixepah Jan 10, 2008
    I tried plugging in the DVR into the DTV input one more time, powered down everything, then plugged them back in. I now get 1080i through the DTV input!! However, and this is a big however, I cannot play the xbox360 using the DVD component input. When playing a DVD through the 360, it works. But when trying to play a game, it doesn't so I have to use composite and it looks terrible! What the hell is wrong with this tv? The 360 works when using the DTV input, but why not the DVD input?
Can't change my DVD player from 480 to 1080
You should use an HDMI or Component cables to connect to your TV. BluRay can support 1080P, but older DVDs only support 480i 480p, and 720p output.
Dec 01, 2014 | Televison & Video
My toshiba tv 46inch 1080p says that it's on
Your TV can only present resolutions as good as the source you provide it. For instance a standard DVD likely provide 720 or less resolution while a good Blu-Ray will deliver 1080 content to you TV and show "1080" as it receives the data from the Blu-Ray player as the movie begins. You may see this number switch often even on 1 single DVD as the resolution often changes between movie trailers and the main content and menus can all have different qualities. So, your TV is only as good as the content you feed it. It can not make the content better then the original source you provide. Hope that helps
Jan 22, 2012 | Toshiba Televison & Video
How do i get my tv to run 1080p
A 1080p set will only show 1080p if the broadcast or satellite co sends it. I don't know of any cable co's doing that as yet. True HD isn't in full motion as yet. 720p is your best right now unless you have a Blue Ray DVD Player along with a 1080p full hd movie then you can watch full HD.
A lot of stations are running 1080i which is good for slow motion movies. 720p is best for fast action movies.
Nov 27, 2010 | Mitsubishi Televison & Video
Does my Toshiba 37HLV66 LCD TV/DVD Combination have the capacity to properly accommodate a Blu-Ray player? Some technicians I have asked say, "yes" and others say "no."
This can be both yes and no. Looking at the specs of your TV it would not be displaying in full 1080p (The highest resolution for HD)
The best part of Blu-Ray is viewing this in 1080p. Your TV can accommodate a BD player and would be best set up using the HDMI input port on your TV. But, it will limited to your resolution of 720p or 1366 x 768 on your TV and most DVD players can upscale the quality of a movie to 720p or higher. It would be worth getting a TV that has 1080p to go with a Blu-Ray Player.
Nov 03, 2010 | Toshiba Televison & Video
I have the LG BD390. I have had this blue ray for sometime and never had a problem with playing blue ray movies. I just bought the new Iron Man II blue ray movie. The movie stops playing at the same...
I had the exact same problem with my BD390 and another LG home theater system, both with the current firmware updates. I noticed others have posted this issue on various sites as well. I called LG and the guy I spoke with seems to have been coached pretty well on the scenes where this problem is occuring since he could sight the exact scenes that were giving me the problem. He claimed the blu ray probably isn't exactly 1080i or 1080p and that the player is probably having problems processing the resolution so I should lower it to 720p. This didn't fix the problem and didn't help explain why my blu ray player which plays plenty of other high resolution movies only has a problem with this movie. I think a firmware update is needed to fix the issue but I'm not holding my breath that LG will be proactive in getting that out soon.
Sep 30, 2010 | LG BD390 Blu-Ray Player
I bought an insignia 26" 1080p yesterday and the display shows that the tv is currently showing the picture at 720p. How can i adjust this so that it is 1080
Generally speaking, your TV will display the signal it receives. DVD player output, for example, is 480p, but an upconvert DVD player can output the signal at 720p or 1080p. You should adjust your components (e.g. cable/satellite box, DVD/Blu-ray players, etc.) to the desired compatible output.
Jun 15, 2010 | Insignia 42" LCD Flat-Panel HDTV
How do I get 1080 on TV
You only get it if they send it. Only Blue Ray DVD's are in 1080p and games I suppose, as of this time. everything else is 480i or 720p. As your manual says "TV CAN GET"--- not produce what isn't there. I hope this helps.
Jun 24, 2009 | ViewSonic N2635w 26 in. LCD Television
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Mitsubishi WS-65905 65" Rear Projection Television Logo
340 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
