Hi
Thanks for using FixYa. Many dishwashers (but not all) use a BI-metal strip that heats up once power
is applied to it. The BI-metal strip bends and allows the soap door spring to
open up the dispenser. This bi-metal strip is not given full 120 volts power,
the timer "shunts" the power through either the heating element (
most common ) or the motor and this gives the bi-metal strip lower than full
power to work and open.
Most often the bi-metal strip has lost its ability to
bend properly and needs to be replaced. Older Kitchen-aid dishwashers used a mechanical
arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic
liner) Kitchen-aid dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax
motor slowly moves and pushes the plunger and door open. And, if this wax motor
doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further
assistance.
Thanks
Rylee
