Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Prefect focus control
Could someone tell this dummy how or where I find the perfect focus feature for my TV- thanks
    President:
  • 4,402 Answers
Go to menu>
push ch down to select function
then press vol +
now press ch ^ and select convergence
then press vol +
press ch Down and select perfect focus,
get then manual here
http://downloadcenter.samsung.com/content/UM/200306/20030623145817468_P55A_00054A_02_0424.pdf
http://www.samsung.com/ca/support/productsupport/download/FileView.aspx?cttfileid=37697&type=TV&typecode=1&subtype=Projection&subtypecode=&cmssubtypecode=103&model=HCN4226W&filetype=UM&language=
Posted on Jan 04, 2008
  • Cary Farah
    Cary Farah Jan 04, 2008
    go to menu>
    then press vol +
    then press vol +
    http://downloadcenter.samsung.com/conten...
    http://www.samsung.com/ca/support/produc...
  • 71 Answers
On the remote you have a door. Open it and you'll find the button focus on the right side the second from up to down. If not is in the menu, go in setup, convergence, auto, ok.
6ya staff
SOURCE:
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner!
In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
Oct 13, 2014 | Electrolux 4.2 Cu. Ft. Front Load Washer...
The focus is off and when I try to do the prefect focus it stops at 44 why and how can I fix this or is my tv done for
You are saying the focus is off, but if the colors are not overlapping, your convergence is off. This makes things look out of focus. If it is the convergence you should see halos of color around things, especially text. You also said that perfect focus does not correct it. That leads me to believe you need new convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to solve it and where to get the parts. If after following the instructions your set still has a problem check my tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which explains what else could be wrong, how to repair it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 27, 2010 | Akai PT5598HD 55" Rear Projection...
What is 4.73 help system? i'm trying to install the software that comes with home budget for dummies and it tells me i need the 4.73 help sytem to completely install. Also, i'm using windows 7. thanks for...
It is compatible with Microsoft Windows 98, Microsoft Windows Millennium Edition (ME), Microsoft Windows 2000, Microsoft Windows XP It does not list a driver for Vista or Windows 7 which makes me believe it is not compatible. here is a link to the web although it is extremely limited http://www.dummies-software.com/features.php?prod=3
Dec 31, 2009 | Anuman Interactive Home Budgets for...
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Blue convergence
SINCE YOU HAVE REPLACED THE CIRCUIT BOARD,THE NEXT STEP WOULD BE CHECKING VOLTAGES GOING TO THE CONV. BOARD COMING FROM THE POWER SUPPLY CIR. BOARD.....IF NO VOLTAGE METER,,SOMETIMES, THERE ARE FUSES ON THE POWER SUPPLY CIRCUIT BOARD THAT SUPPLY THE NEEDED VOLTAGES FOR THE NEW BOARD YOU JUST REPALCED...UNPLUG THE SET,,CHECK FOR A BLOWN FUSE----I THINK THERE IS 2 OF THEM--ONE FOR A NEGATIVE VOLTAGE AND ONE FOR A POSTIVE VOLTAGE FOR THE CONVERGENCE BOARD..GOOD LUCK--SORRY, MIGHT NEED A TECH...TUNICA
Oct 30, 2008 | Samsung HCN653W 65" Rear Projection...
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Blue blurry on perfect focus
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Jan 13, 2008 | Samsung PCN5425R 54" Rear Projection...
Tv not working good
please can you tell me you are getting light or not along with suond so i can give you perfect idea of what problem is
hope you will help me in solving the problem.
Oct 14, 2007 | Orion1934 19" TV
White tint/haze
Check any/ all pico fuses in power supply. PVAT! Look for evidence of CRT coolant leak. Since Perfect Focus is a function of convergence,you might consider replacing convergence IC's,then perform alignment in servicer mode,then finish w/Perfect Focus.
Sep 28, 2007 | Samsung HCM4215W 42" Rear Projection...
This tv has been a nightmare, its been down 3 times in 4 years.
The convergence board, AA95-01799G is available from http://www.samsungparts.com for about 122 bucks + shipping. You also may need to get the service manual so you can do the convergence alighnments with this set when you replace the board. You will also need the manual to perform the perfect focus alighnment on this set if you have that feature. Good Luck
Mar 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
