Printer won't take my paper to print
I have a HPphotosmart 2570 all-in-one series printer I bought in 2005 it collects dust and am frustrated because it printed for about 6 months and quit it always says PAPER JAM and theres not .I've tried everything I thought it seems it doesn't want to bite the paper to pull it in. I hardly used it much! Please help me
  • Jodes74 Jan 07, 2008
    My C82 printer - was printing and then just all of a sudden stopped, so I pulled out the paper that it had finished printing, and then it just wont work.
dodgecharger
  • 254 Answers
SOURCE: What paper jam?
Does the printer even try to pick a piece of paper from the supply tray? If not, then it would appear that a sensor somewhere in the paper path is bad, either mechanically or electronically. Often, these sensors have a lever which touches the paper. If by chance the lever is broken or stuck it won't give a correct message to the logic circuit. If by chance the sensor is electronically defective, it would still give a bad message to the logic, and it would need to be replaced. Logic circuitry could be bad, in which case, replace the printer. With the lowcost printer/all-in-one units these days, it seems fixya has a continual flow of inquiries. Maybe this will give you some help.
Posted on Aug 09, 2007
SparkGap
  • 363 Answers
SOURCE: paper jam
What happens when you close the top?
Posted on Oct 01, 2007
SOURCE: HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
Posted on Feb 25, 2009
bard-dann
  • 19 Answers
SOURCE: Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Posted on Jul 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Canon ir 2570 error code 7356
The printer knows if it needs paper by a sensor. Usually this is is a light beam across the paper supply. Both ends, the light and the sensor can get covered in dust and may need to be cleaned
Apr 27, 2014 | Office Equipment & Supplies
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Nov 03, 2009 | Konica Minolta Magicolor 2450 Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Printer will not grab paper
Check to make sure the paper sensor tab moves freely. You might try air dusting around the paper pick-up rollers to make sure the area is free from any accumulation of dust, dirt, or paper residue.
Nov 19, 2008 | Office Equipment & Supplies
My printer is a MFC-685CW made by Brother. We cleared a paper jam and unplugged it as it suggests to do in our user manual. Our screen still says Unable to Print AF. Can someone help, this is very...
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
http://www.fixya.com/support/t227515-printer_paper_jam_brother_mfc
Aug 23, 2008 | Brother Office Equipment & Supplies
Printer problem
no harm in reloading try it. please get back with your findings
Apr 02, 2008 | Office Equipment & Supplies
135 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
