Question about Sony Playstation 3 (PS3) Console
PS3 Bought used PS3 from eBay. (probable mistake) Light blinks red (NOT overheated, starts blinking immediately) Re-setting by holding down puts it back in stand by mode, but the second you touch the power switch , it turns green for a second, makes a motor noise and then starts blinking red again.
    Sergeant:
  • 271 Answers
It sounds like your power supply is faulty or you need to make sure all wires are in properly if that don't work leave it in stand buy mode for 12 hours do not touch it at all or you will have to do it all over again it needs the back up battery to gain more power let me know how you get on
Posted on Jan 04, 2008
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
I have a 60gb Phat Ps3. I recently went to update it to the latest firmware and it downloaded the update fine and was running normally. Then as it was installing the update, the system shut itself off...
Hello there vincent
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Aug 29, 2011 | Sony Playstation 3 (PS3) Console
Ps3 stopped suddenly working and red light blinking push the on/off button the light stops blinking and stays fix red push again turns green few second then red blinking again any idea what may have...
Hi Andrea.
What your experiencing is the the well known "PS3 Red/Green Light of death" which generally means a hardware failure or overheating. If it's overheating (2 Red lights) then it will automatically shut down after a while but from what your saying it's not overheating.
If you have it in warranty you have to send it to Microsoft and they will send it back usually 3-4 weeks or take it to a reputable gaming console repair shop (this will cost money).
But first check that your AV cable is properly plugged in (in this case all four RED lights are bleeping). If you're using an HDMI connection forget about this step.
So if you don't have a warranty then it will cost you about $150.
Another thing you can do is follow a guide and repair all of the errors with the PS3 including your problem. Click here for more information.
May 19, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 wont turn on. The console beeps like normal, then the light quickly turns from red to yellow then immediately back to a blinking red. What does this mean?
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
check your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit.Then unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating.
click here to download ps3 repair guide
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
PS3 console shuts off with a yellow light and then immediately goes to a red blinking light and then does not start again.
1. Allow your PS3 to cool down. Overheating is known to cause the red blinking lights and the yellow light of death. Turn off your console for at least 20 minutes before turning it back on.
2. Check for a connection problem (loose cable) with your hard drive. If not, restart your PS3. You can also unplug all cables except the power cord and re-plug them back.
3. Lastly, reset the hard drive by taking it out and putting it back in.
( I would power off the console and use a keyboard duster to spray in one of the vent holes, this overheating issue could be caused by excess dust. Is it in an open area with good air flow?
Rylan
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
When system is turn on its beeps red and turns off
The blinking red light usually indicates hardware failure. If your Ps3 is still under warranty you should contact sony have them send you a box with free postage and send them your console. They will locate and fix the problem for you.
If your console is not under warranty anymore there are a few things you can try.
First remove the hard drive and try booting up your console. If it says no drive found shut the console down and put the hard drive back into place. If it works after that then the issue was just a drive error which is now corrected. If the light is blinking again then the drive itself is bad.
Second turn the ps3 off for 60 seconds by using the switch on the back. Now hold down the eject button and turn the power switch back on while your still holding the eject button. This can help with overheating issues.
If these simple fixes dont resolve the problem then you will need to contact sony and ask about repair cost's. As fixing it yourself would require experience in working on gaming consoles.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Unable to turn console on. Red light flashing
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont work
I sure wish I could because I have the same problem. I purchased an almost new ps3 from a seller on ebay and all I get is standby then when I try to power it up, I get the blinking red light. Sony wont help because I purchased it from ebay so I am not the original owner. The seller wont help, he swears it didnt have that problem when he shipped it. Ive tried removing the hd, holding down the power button, unplugging it in the back, and nothing helps.
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
105 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
