Gateway 7330GZ PC Notebook
System locks up
shared by 3 users
posted by brian1971 on Jan 04, 2008
While doing a system recovery, without disks (I can't find them), it gets half-way then locks up. Cursor does not move, and nothing happens
Comment posted on Jan 15, 2008
OK, I now have the restore disc from Gateway ($20 not bad) and it seems to install. But, after the restart it gets to almost to the end and it freezes up. Cursor doesn't move, caps lock doesn't work, and the HD led is out. How can I run diagostics test on HD? I'm a rookie!!!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by jamielicardo on Jan 29, 2008
Hi i have the same problem get to half way and stops working i'm trying the step of disabling speed but i would like to know where i can get the reboot disc for $20 please let me know Email is jamielicardo@verizon.net
Posted by mooseQQ on Jan 21, 2008
Hi, I have the same problem now. I wonder if you have tried to set the BIOS as the best solution you rated ? Does it work ? Thanks!
Best Solution
posted on Jan 05, 2008
FixYa! (100)
headstrong
Rank:Guru Guru
Rating: 86%, 254 votes
any lights flashing on PC when it locks up?
try doing a hard drive diagnostics if you can, if it hits a bad sector on the drive it could lockup because it can't write to the drive
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on system locks up:
I don't want to Accept this solution
Best Solution
posted on Jan 14, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
change the Intel SpeedStep setting from Enabled
to Disabled. in the Bios setup under advanced .then do a system restore
Rating Locked! (?) brian1971 has rated this solution as Helpful
Thank You!
Solution #3
posted on Jan 12, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
I had this problem for a long time, two motherboards later and an updated system disk, "which i had to buy off of gateway" I finally had a working laptop. Its not even close to when i first bought it though, slow as a snail! Gateway sucks!
Rating Locked! (?) brian1971 has rated this solution as Thanks for Trying
Thank You!
Can you Help with these PC Laptops problems?
I still am not sure what is keeping the laptop from...
When power up button pressed I get a yellow power...
I turned on my notebook and it is stuck on the Gateway...
Is it expensive to fix and can I do it myself if a novice?
I have tried to load the drivers for the network adapter...
Loading problems.
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
