Dryer turns on and I got the panel to work again, count-down works for timed cycles but no heat or tumble. here's what I've done so far... I took the entire thing apart and cleaned it. And yes, I do mean the entire thing. First symptoms were front panel didn't work so I was leaning toward the "motherboard" on the inside left side as you look at it but when I took it all apart and cleaned it, I got that problem fixed. I checked the motor for a reset and took it out and cleaned it and checked all the belts and they all look fine but couldn't find any way to reset the motor. The heater element wasn't popped or broken that I could ascertain but when I put everything back together, I still didn't get any tumbling action out of it. I have to admit, the thing was FILTHY... my sister hadn't cleaned it in probably 5 years since she first got it...
Common faults -
1 The heating elements can fail
(meaning open circuit)
2 There are cut-outs (T.O.C's) that
might need resetting
3 The thermostats (stats) can trip
out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave
programs that can fail and circuitry although most should produce an errorcode
showing you were the fault is.
5 Faultyconnections and burned wires may also be
the fault.
Free tumble
dryer repair videos
We have a Free full video library on appliance repair video’s
