Question about HP iPAQ RX3715 Pocket PC
Audio issues... Recently, my rx3715 has had trouble with its audio. It will pick up headphones occasionally, but often in only very specific (random) positions of the plug (I have to spin it until it connects and then if it gets hit at all i lose it). The sound is fine when its connecting, but it doesn't do it often. Also, when there is nothing plugged in, it (i think) picks up that it DOES have headphones, and so i get no sound. Frequently i have to stick the stylus in the headphone jack in order to get some form of sound. It's almost as if it's reversed as to whether it's registering headphones or not... I don't think its broken, but i have no idea what it could be!
I had this same problem. The headphone jack is coming loose from the main board. Instead of getting repaired I purchased some bluetooth compatible headphones. DON'T get the ones made for the ipaq by HP. Lots of breakage issues (including the one I purchased).
Good luck
Posted on Feb 20, 2008
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
I have a Grundig TV model: GU22WDVD10, my sound has randomly stopped working when connected to my ps4 but works connected to my Xbox? I have tried different HDMI cables and still no sound
does the tv have audio in if yes try this,,,,use your tv instead of headphone ,,,, For the PlayStation 4, you can just use a regular set of 3.5mm headphones to hear game audio through the port on the DualShock 4. To do so, from the PS menu, go to Settings > Devices > Audio Devices > output to Headphones > With yourheadphones plugged in select "All Audio" as opposed to "Chat Audio You can also adjust the volume from Audio Devices > Volume Control (Headphones) - tv. this may work
May 17, 2016 | Grundig Televison & Video
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
Audio stops at random times throughout the day, and says no speakers or headphones are plugged in but the speakers have never been unplugged
hi it could be driver or hardware problem. 1. Try to install your audio driver then try using different audio players it could be a conflict to some audio program. 2. It could be some foreign object inside the headphone plug that stays on the headphone mode.
Sep 17, 2011 | Computers & Internet
I recently bought Conga Wesc headphones but I have a problem with the extension cable. When I listen to music without the extension cable works both audio channels but when I connect the extension cable...
Since the problem goes away when you don't use the extension cable, the cable is the trouble. One of the wires inside is broken. A new cable is what you need.
Jul 04, 2011 | Wesc Conga Headphones
Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple MacBook Pro Notebook
Rx3715 battery power trouble
Did you check if the PDA was hot? My battery was totally dead one day when I picked my 3715 up, just to found out it was blistering hot (was turned off) and even the backup battery was empty. Running fine now after hardresetting it, but still...
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
