2008 Honda XR 125 L Logo
Anonymous Posted on Nov 03, 2009
Blown cylinder head gasket
My cylinder head gasket has blown, how do i change it and do i need a torque wrench/
scottbullett
Level 2:
New Friend:
  • Honda Expert 139 Answers
  • Posted on Nov 05, 2009
scottbullett
Honda Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
58324
Points
280
Are you sure the cylinder head gasket has blown and not the rocker cover gasket this is at the top of the engine its rubber if it has it takes just a few 10mm bolts to undo then replace the gasket and no need to time up'.if you have the head gasket blown very rare you should buy a workdhop manual
2 Related Answers
Anonymous
  • 269 Answers
  • Posted on Nov 03, 2009
SOURCE: my Honda xr125 has a
You would benefit from purchasing a service manual for your bike, as it should have detailed directions and information on the repair you need. Yes you will need a torque wrench, if this is your first "big" repair, please get a manual and follow the directions closely, otherwise you could do additional damage to the motor. Hope this helps and good luck.
JP
Testimonial: "thanks "
Anonymous
  • 323 Answers
SOURCE: the cylinder head gasket has blown. how do i
This is one of those times I recommend you load it up and take it to a Honda shop. There may be more than a blown head gasket. And by the fact that you ask if you need a torque wrench we can tell you are not used to jobs of this nature. You most definitely need a torque wrench, torquing a head is one of the most important things about a bike. Spend the money and know it is done right.
2answers
I had a brown head gasket on my 4jg2, the head had a warpage too, skimming was done but outing it back with a new gasket, air bubbles are not stopping, no visible cracks on the head. What could be the...
Firstly the sort of crack cylinder heads suffer from are most often not visible which is why pressure testing is important especially if the previous blown gasket had resulted in a nearly cooked engine.
Uneven heating of a metal mass will always cause distortion and uneven cooling often causes a crack - this is often the consequence of leaving a failing head gasket until it has failed.
It isn't unknown for the top of a cylinder block to need attention due to corrosion or warpage. It isn't unknown for a cylinder block to crack, it also isn't unknown for head bolts to stretch and bottom in the holes especially when the head has been skimmed...
It isn't unknown for amateur mechanics to misinterpret the cylinder head bolt tightening method when it uses a mixture of conventional torque wrench and angular torquing.
2007 yaris 1.5 Ing. What's the torque pressure on heads
PDF]Complete Cylinder Head Torque Specifications for Domestic ...
olybrake.com/pdf/fel_pro_torque_specs_guide.pdf
When you consider what can go wrong when even "minor" gaskets fail, ... and engine block, tightening the head bolts compresses the gasket slightly, allowing ...Missing: ing
How To Torque Cylinder Head Bolts - EricTheCarGuy ...
? 25:08
https://www.youtube.com/watch?v=5WHBskK_F3o
Aug 29, 2010 - Uploaded by EricTheCarGuy
How To Torque Cylinder Head Bolts - EricTheCarGuy http://www.ericthecarguy.com/ Well ... What's the reason for changing the torque pattern?Missing: yaris
CTA Tools 9295 Toyota Head Bolt Wrenches -Dou
2helpful
I HAVE STEAM & ANTIFREEZE COMING OUT OF TALIPIPE
Best case, blown head gasket. Worst case, cracked cylinder or cylinder head. Unless your engine digested something like a bolt, 99.9% of the time it's a head gasket as mentioned above. Usually nNot something for someone lacking tools and experience to try and tackle, unfortunately. Maybe with the help of the internet and being resourceful, you could attempt it with success. Take pictures upon disassembly, get a box of ziploc bags and a marker and label each and every set of screws and bolts as you disassemble, putting them in separate bags. The intake and cylinder head has a torque sequence and setting. you'll need to discover that sequence and torque setting. Sometimes it's a measurement in ft lbs, where you'll need a torque wrench and sometimes it's angle torque, where you'll use a torque wrench to start and then need an angle meter to measure the degree of turn beyond that. You cannot reuse factory head bolts, so get replacements.
Make absolutely sure that you thoroughly clean the head and engine deck surfaces until they wipe clean with a white rag and lacquer thinner. You should also take the head to a machine shop and have it surfaced, if not consider reconditioning the head with a valve job, new springs, retainers and seals or buy a reconditioned head.
1helpful
3answers
How do you replace the head gasket
with great difficultry, It is verry time consuming end verry costly to have it (Replaced)
My truck is blowing white smoke and will idle for about twenty minutes and then cut itself off.
white smoke means there is a presence of water/coolant at your combustion chamber. common cause of this is blown head gasket and/or small cracks/holes in your cylinder head. if this happens, water will not circulate properly in your engine thus the vehicle will shutdown due to over heating.
what to do:
1. replace head gasket. this is quite not a DYI fix since it will require some tools like torque wrenches and some knowledge on timing.
2. if replacing the head gasket does not solve your problem, have your cylinder head resurfaced at the nearest car service center. resurfacing makes sure that your cylinder head perfectly fits with the crank case.
I have a blown head gasket. What steps would I need to go thru for self repair?
I would not recommend doing this work at home. It requires specialized tools, such as a torque wrench, piston ring compressor,and a good manual for torque sequence and values. Furthermore, most blown gasket mishaps require bringing the head surface back to flat and true.
Blown head gasket how to repair it
The only way possible: remove the cylinder head and replace it. And do it quickly because a blown head gasket can seriously damage an engine if left unfixed.
This is a serious job, which requires mechanical knowledge and some special tools - a torque wrench is mandatory.
1helpful
My Honda xr125 has a blown cylinder head gasket. how do i change it and will i need a torque wrench?
JP
1helpful
The cylinder head gasket has blown. how do i change it and do i need a torque wrench?
2helpful
1994 old cutlass ciera 3100 blown head gasket.
Get a Chilton's book on the car. It will take you thru the whole job, and give you the torque specs for putting it back together. You will need a torque wrench, foot pounds, and a good socket set.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
