Computers & Internet Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn it on inmediately it turns off by itself
Anonymous
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
54520
Points
595
Does it have a proper amount of battery charge? try removing the battery and plug the ac adapter and see if it turns on (without turning off) using only the ac adapter. else, there could be a hardware problem on your laptop
My pc turns on and inmediately turns off
see if the fan on cpu is working make sure that the cpu has cooling grease. if the heatsink not big enought it will shut down just like that ok
Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
Treadmill will turn on then quickly stops
by lack of maintenance LUBE schedule in your deck belt, the machine protect itself for electronic system. LUBE inmediately the deck belt, Maybe you have a WORN deck belt.
2) LUBE the rollerrs bearing too.
3) Test the input voltage motor, if there are the motor need repair.
4) Test the drive belt motor, and adjust it or repair or replace.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
Display screen dont work
try to RESTORE to some point that was working before.
if work pass the antivirus inmediately.
Maybe the toolbar installed
is malware! remove it
God bless you
When you start the treadmill the speed moves up by itself
Dear Sir:
This is bad adjustmente from speed sensor, clean, and tigh the connector very well, maybe can be faulty s. sensor.
By that reason RUN inmediately the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
2answers
EL EQUIPO SE APAGA
Can you rephrase your question in English?
2answers
HP VP6111 dlp projector turns on and shuts off inmediately
I think try to check the power supply of the projector and also check if its overheating.
My car stereo does not work I turned on and inmediately it turned off by itself the model is rampage AV 455
an ANSWER to this is toss that piece into the trash can, and upgrade to a good brand, alpine is not bad.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
