Question about GE WSXH208A Front Load Washer
Washer continues to have to be restarted
The washer eill stop in the middle of a cycle and the start button will start flashing. It will not continue unless you press the start button. This happens all through every cycle. PLEASE HELP. THIS IS DRIVING ME NUTS. Already checked the pump filter.
  • Tired in CA Jan 04, 2008
    My drain hose is exactly 3 feet from floor. Stand pipe is clear. Loose fit around spigot. Everything is clear and it still stops in cycle and flash. Any idea what else it could be.
    We are in the US
  • thony Jan 06, 2008
    Brand new washer...same problem.  I need help too.  It's not the drain hose, its not the filter.  This machine sucks!!!!!!!!!!  If this machine needs to be repaird already.  I'm buying a Bosch.  Another reason why I buy foriegn designed products.  Their just better.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped. Which country are u from?
Posted on Jan 04, 2008
Testimonial: "Found to hose to be plugged. Thanks"
  • prem mathew Jan 04, 2008
    Pl go to "trouble-shooting" above & sift thru, you may find some useful info, meantime someone would help, god willing.........
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Feb 15, 2008 | Washing Machines
GE WSXH208A Front Load Washer Logo
74 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
