This is one of those times I recommend you load it up and take it to a Honda shop. There may be more than a blown head gasket. And by the fact that you ask if you need a torque wrench we can tell you are not used to jobs of this nature. You most definitely need a torque wrench, torquing a head is one of the most important things about a bike. Spend the money and know it is done right.
SOURCE: my Honda xr125 has a
You would benefit from purchasing a service manual for your bike, as it should have detailed directions and information on the repair you need. Yes you will need a torque wrench, if this is your first "big" repair, please get a manual and follow the directions closely, otherwise you could do additional damage to the motor. Hope this helps and good luck.
JP
Testimonial: "thanks "
SOURCE: blown cylinder head gasket
are you sure the cylinder head gasket has blown and not the rocker cover gasket this is at the top of the engine its rubber if it has it takes just a few 10mm bolts to undo then replace the gasket and no need to time up'.if you have the head gasket blown very rare you should buy a workdhop manual
