In order to provide a correct dianosis and cure, I will need to know the model number and in which direction the bow occurs. Does the curve occur from the top and bottom toward the center or from the sides toward the center? There are different circuits involved in these case.
Please update this and I'll provide a solution.
Thanks,
Dan
If I read your response correctly, a door would look like this: )(
If that is correct, the problem is the pincushion circuit. There is a cap that goes bad in that circuit that can cause this. I don't have JVC info available to me online, so it make take a day or two to get you the parts required. Typically the part cost to repair this will be less than $10.
Stay tuned...
Dan
the curve is top to bottom for example all doors in picture would look bent. The model no is JVC AV28T5SR.
