Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Green light blinking, tv won't turn on
We have turn off the power, and hit reset button and light keeps blinking. has been blinking for over hour now
same problem
  • 9 more comments
  • frankcathy Jan 04, 2008
    January 4, 2008
    Our tv green light has been blinking for over an hour. We are experiencing
    stormy weather and power has gone out. After it was restored, we have
    not been able to turn the tv on. We have tried unplugging the tv from the
    surge protector -- tried the reset button on the tv numerous times and
    still no luck.
  • dwmsdsl Apr 05, 2008
    green blinking light and TV won't turn on.
  • ekilgus Apr 20, 2008
    I have a 65813 TV with the same problem. Yesterday it was working fine then today the green LED just blinks. All indications from what I've read is that the 4 DM module capacitors need replacing. I would do this except I have an extended warranty. I'm assuming that if the tech doesn't want to do any soldering he will just replace the DM module. I suppose I would be better off with a new DM module than a repaired one. However, if I'm allowed to keep the bad DM module I'll repair it myself and keep it for a spare. Is my reasoning regarding what's wrong correct? Aren't these DM modules expensive?
  • Bad Day May 03, 2008
    Was useing a power tool an kicked the circuit breaker, TV was plugged into a dif recepticle, but same circuit. Turned breaker back on, green light just flashes, tried reset,tried unplugging for several minutes, no luck. Unit is plugged into a Monster Power HTS 3600 filter, btw.
  • mune237 Jun 05, 2008
    my ws-65813
  • rjstocke Jul 03, 2008
    Same green light blinking problem. Lost Power to unit . Power came back on the I had a green light blinking on the front of tv. Tried turning off,pushed reset button, nothing seems to help. TV will not power up. I understand there could be a problem with the DM Module. It apears Mits. has a factory flaw in these units. Any suggestions.
  • kempo98 Jul 06, 2008
    Same problem as others; light will go off over time and then I can use remote to turn on. Attempted same solutions as others.
  • Anonymous Sep 21, 2008
    MY TV IS A MITSUBISHI WS DIAMOND 65 IN THE GREEN LIGHT ON FRONT HAS BEEN BLINKING FOR A WEEK AND THE ON OFF WILL NOT WORK OR ANYTHING I HAVE A TV REPAIRMAN COMEING OUT THUR. I JUT WANTED TO SEE IF YOU KNOW ANYTHING THAT COULD HELP THANKS ALVIN AT okcfire1981@aol.com
  • gegztoy Oct 12, 2008
    Same thing here. It was working fine last night.
  • dakatz Nov 23, 2008
    same problem
  • Anonymous Dec 02, 2008
    won't turn on, green led blinking.. I've tried unplugging, resetting.. still under my extended warrenty - but this is the 3rd time in 5 years that I have had this issue.. it's a pain in the **** - especially when we use this as our main TV.
    Genius:
  • 1,153 Answers
Look for DM board repair here in threads
Posted on Jan 04, 2008
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
Jan 17, 2008 | Mitsubishi WS-65813 65" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Apr 03, 2010 | Mitsubishi WD-52528 52" Television
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
Nov 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
1,025 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
