Question about Delstar DS 31024 MP3 Player
Static Electricity I received my delstar mp3 player for Christmas, and I have misplaced my manual. Today, as I grabbed it, I got a shock of static electricty and now I can barely hear the songs with the volume at 31, which is the highest level, and the right ear phone, is making a high pitched sound. I thought at first it was my ear phones, so I put another set in, but it is not them. Is there a way to solve the problem or am I doomed to not being able to use it again.
If you created a desktop folder of the tunes you transferred to the unit... reformat! that will make the re-transfer of your tunes much easier. the unit is metallic and static is bad but unless you put it in the microwave you should be able to revive the Delstar 31024.
easiest way: erase the memory via the usb. look for the 'removable' storage device from 'my computer'. open the folder and single click the top file. scroll to the bottom of the list and WHILE holding down the SHIFT key single click the last item. you have now 'blocked' or selected all files. 'right click' select delete. poof, you're empty.
disconnect the Delstar from the computer by a single click on the usb icon displayed in the lower right corner of your computer's desktop (look for the clock) follow the prompts to properly disconnect.
remove the Delstar31024 triple"A" battery let the unit sit for thirty seconds, then reinstall the battery. don't turn the unit on until you've reconnected via usb to the computer and recopied all of your files back!
Posted on Jan 14, 2008
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
I received a NEW dyson ball vacuum for Christmas. I have noticed when I vacuum with it that dirt collects all over the ball and the vacuum beater head. Is this normal. I have had the regular upright...
This may sound silly, but it sounds like that you a have static electricity problem. If the dust is collecting on top (outside of the brush head that is probably the static attracting it. This is common during the colder months. You know how during these months when you walk across carpet and then just someone or a metal objest, you get a shock.
You might try lightly spraying a little "static guard" on the top of the brush head before using it, or using a carpet dusting product that smells good, and may reduce the static.
Jan 01, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Have iLive ihs3 2.1 speaker system. The speaker was sitting on top of the television, roommate was dusting the tv screen and elbow touched iLive speaker. There was like a static electricity shock, and...
Unfortunately I don't think so. TV"s can develop a huge static charge & dusting would increase it... that Discharge was a huge shot of Static Electricity, most likely fried ya output devices...
Feb 02, 2010 | Audio Players & Recorders
Electric shock when leaving car
Although it's possible that there is an electrical problem in your car, it's more likely that the shock you're feeling is naturally occurring static electricity.
If your tires were replaced as part of the front end repairs, it's possible this is the cause. Cars naturally build up static electricity from rolling around on rubber tires (the same thing that happens when you rub a balloon on your hair). This static used to get dissipated through the tires to the ground -- however, new, fuel-saving tires with lower rolling resistance are made of a rubber compound that doesn't dissipate static electricity as well as the old stuff. (The price we pay for better gas mileage.)
The static builds up in your car, and then gets discharged through you when you get out of the car and complete a circuit between the car and the ground through your body.
One solution is to attach a ground strap to your car. You can buy these rubber strips from most auto parts stores. One end attaches to a metal part on your car. The other end drags on the ground and dissipates static through it, rather than through you.
Sep 13, 2009 | iLO XM-MP3-CD Car Stereo
Static electricity
everything works but no volume comes out the dock or the head phone plug??
if it's the head phone plug you could have burnt something out in between well i guess that would be true either way
if it is the head phone plug there is a good likely hood you can get away with minor wallet skimming
if it's both then you got me and if it's the dock then just be happy it's not totally blown
Mar 25, 2008 | Apple iPod MA446LL/A MP3 Player
Downloading mp3 files from my computer
I NEED A MANUAL FOR MY DELSTAR 1 GB. MP3 PLAYER. CAN YOU HELP
Mar 07, 2008 | Delstar DS 31024 MP3 Player
I can't find the manual for my Delstar DS 31024 1 GB MP3 Player
throw the thing out and buy something a little more durable and that actually works
Jan 31, 2008 | Delstar DS 31024 MP3 Player
Delstar DS 31024 MP3 Player Logo
64 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
