Question about Sanyo DS24425 24" TV
Need converter box
Want to know if need converter box on my sanyo tv thank you
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Posted on Mar 03, 2008
I have a RCA Converter box. ATSC mfg Dec 2010. I need the access code for the tv I am hooking up this converter box too. Sanyo Television. Thank you
Hello
Try these links.
tv.manualsonline.com/.../rca/...converter-box/remote-instuctions-213
Try these codes too:
037, 082, 083, 124, 198, 268, 274
http://www.dataentryjobs.us/67948.html
Feb 08, 2012 | Televison & Video
Do I need converter for Sanyo DS24424A manufactured in 2005.
hiya
what you may need is a freeview box unless ur tv has in built digital
rik
Feb 24, 2009 | Sanyo HT27546 TV
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Converter boxs
If you have cable or satelite service, no converter is needed for either one. The only time a converter is required is if you receive the TV signal from an antenna (over-air). The DS19130 WILL require a converter for over-air broadcasts. I think that the DS25530 will as well, but I am not 100% sure. Because of its age, I would suspect that a converter will be required for hte DS25530.
Dan
Sep 16, 2008 | Sanyo DS20930 20" TV
Digital capable
You will only need the converter box if you use an antenna. If you have a cable tv service, they will do the conversion on their end.
Jul 19, 2008 | Sanyo DS31520 31" TV
Digital ready?
Sanyo's customer service responded that this TV is not digital. If it's connected to an antenna, you will need to purchase a Digital to Analog converter box.
May 11, 2008 | Sanyo DS19310 19" TV
Is this an analog or digital television?
I e-mailed Sanyo, and their response is that this TV has an analog tuner so you will need a converter.
Feb 23, 2008 | Sanyo DS27510 27" TV
No real problem yet
yes,,,ur TV is a digital one...
Jan 28, 2008 | Sanyo DS25390 TV
Sanyo DS24425 24" TV Logo
159 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
