Question about Sanyo DS32224 TV
32" TV Screen Problem
I think my TV is a DS32224 model. The screen suddenly narrow in the middle much like an hour glass. The picture is till clear, it just doesn't fill the screen anymore. I can find no setting in the menu that helps. A also reset the tv to factiry settings to no avail.
  • HelenH Mar 15, 2008
    Our Sanyo DS32224 TV appears to be blurry. When numbers and letters are shown, it seems that they have shading turned on. I tried adjusting and resetting to factory default and none of that is helping. Any suggestions? Thank you.
  • Anonymous May 21, 2008
    The screen narrows in the middle much like an hour glass.
  • Sanyo Master
  • 1,689 Answers
This is a pin cushoning fault. The failure is in the pin amp, and also most likely in the scan amplifier sections. The scan amps and pin amp in part of their functions work together to control the paralax of the picture scanning. They also control the dynamic focus.
To service this, you will need the training, service information, the testing tools, parts availability, and the necessary tools to follow up.
These types of faults can be complex to service, and can be a chalenge to even an experienced tech.
Jerry G.
Posted on Apr 27, 2008
I have Optonica TV , Model # CS 5122.....Bought it somewhere around in 1987 or 88.....faced no problem till now.....But since a couple of days the picture on the screen is not clear & is even blinking...
I have optonica TV model CS5145A brought from mumbai in 1993. But since a couple of months TV automatically trips when I increase the contrast and decrease the brightness and the picture on the screen is not clear ..So can u suggest me which component has to be replaced?. Already i replaced the SMPS and power resister in power supply circuit.
George, Hubli, karnataka Email -
Sep 02, 2010 | Televison & Video
Thin bar in the middle of the screen showing the picture
You should get the vertical IC checked starting with checking the supply voltage on it. This is a small flat IC attached to a heat sink with about 9-11 pins. This tv model should carry an LA7837 or an equivalent IC. If supply is present, check with means of a magnifying glass for dry solder joints on it. Resolder the pins on this IC if necessary and should work out fine. Model tends to suffer from this problem.
Aug 19, 2009 | Sylvania SRT2232S 32" TV
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Jun 04, 2007 | Bush 5693D 24" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
The picture is convexed,or hour glass.
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Dec 22, 2006 | RCA F32672SB 32" TV
Sanyo DS32224 TV Logo
88 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
